My thoughts on the Malossi Multivar
May 16, 2017 15:29:04 GMT -5
90GTVert, spaz12, and 1 more like this
Post by Cincikid on May 16, 2017 15:29:04 GMT -5
Malossi Multivar Model #M5113603
My setup:
2014 Zuma 50F 26,000 mi
L/C Fuel injected 4t RPM limited.
Malossi Multivar with 5 and 5.5 rollers mixed.
Yellow torque spring, Gy6 50 TD, Adly 3 shoe clutch with red springs.
OEM Yama belt.
First impression:
The Multivar comes nicely packaged with all the goodies to get you going, including a color manual detailing fitment, a white Malossi torque spring and six 6g 16x13mm Malossi roller weights.
Holding the parts and pieces that make up the Multivar you notice the quality.
The machining is flawless and all parts fit together perfectly.
Performance:
The objective of any performance variator is to enable you to tune in a way that allows your engine to stay in an RPM range where it performs best, AKA the powerband. All the while giving you a smooth and seamless transition from zero to top speed.
The Multivar does this but with a little something extra. If you've done any CVT tuning you know to get that torquey launch you need light rollers but this takes away from top speed. While the Multivar does not totally do away with this rule it does substantially bend it. Malossi designed the Multivar ramp plate angles to give you both take off and top speed. In my opinion, they have done a good job. With my current setup, I have smooth seamless and constant acceleration. I also have the same torquey take off my OEM Yama vari provided but with a welcomed additional 4-5 MPH increase in top speed. (This gain in top speed is in line with other reviews I've read).
Ease of tuning:
Very tunable.
Durability:
I ride my scoot regularly and in the 4mo I've been using the Multivar, wear has been minimal. My jasil rollers (Inexpensive) are still in good shape with no flat spots. The paint is starting to wear at the top of the ramp plates but there is no sign of groves. The bronze bushing in the center of the vari, face, guides and boss are same as new with no wobble between boss and bushing.
There is no sign of excessive belt wear.
Comparison:
I am basing my comparisons on experience with OEM Chinese Qmb 50 variator, Hoca performance Qmb 50 vari, OEM Yama Zuma 50F vari. Hands down the Multivar has them beat in performance. As far as longevity, only time will tell.
Final thoughts:
I am running the Multivar on a 49cc RPM limited 4T.
On an unlimited 80cc 4t or 70cc 2T, I believe this variator could reach its full potential.
Please feel free to post your experience with the Multivar and other comparable variators.
My setup:
OEM Yama belt.
First impression:
Performance:
Ease of tuning:
Very tunable.
Durability:
Comparison:
Final thoughts:
