Post by stancejontland on Jun 2, 2017 22:53:07 GMT -5
whats up guys just need some help figuring out what the name of this plug is. and where i can get a cheap charger that works with it.
Post by jackrides on Jun 2, 2017 22:55:28 GMT -5
Can't directly answer your question. However, Autozone sells individual crimp connectors that should fit in both male and female.
Post by ryan_ott on Jun 2, 2017 23:03:52 GMT -5
Is that for a battery charger? Looks like the battery tender plugs.
Post by stancejontland on Jun 3, 2017 0:05:38 GMT -5
It's like an adapter to my Razer electric scooter but I gotta plug it into something to charge the scooter
Post by jeff84 on Jun 3, 2017 1:26:19 GMT -5
assuming its a 12 volt battery, I would get a battery tender, it wont over charge it. even if you have to cut that plug off and replace it with one of the battery tender plugs. you can also use it for your scooter batt and car batteries. if its not a 12 volt then you may just have to buy a replacement from the manufacturer of the electric scooter. if you have a batteries plus store close by, you might stop in there and see what they might have.
