Post by dexameth on Jun 26, 2017 17:56:28 GMT -5
So I changed weights this morning. From 6g sliders to a 7/6 mix. Everything was normal looking; Everything passed inspection. Then as I'm scooting on my lunch break and then again on the way home I would feel slipping from a stop (first time for that). Just off the line and really only past half open throttle. So I would lightly twist until I was rolling then nail it. Rpms would hold high until 45ish and then settle down for a few and raise back up after 50. I've ran this setup exactly as described for a long time and tried using a heavier spring... Blah blah I wanted my known-to-work setup back so I did just that. I decided to clean and inspect everything when I got home and found the variator face all scratched up... Little tiny Knicks. See the pictures. The belt looks fine! It's almost brand new, just around 100 miles. I do run an open CVT but I've been blasting off road for a long time and have never seen this until today.
Post by FrankenMech on Jun 26, 2017 20:16:05 GMT -5
Road grit embedded in the belt.
Post by jeff84 on Jun 26, 2017 22:09:08 GMT -5
ive been running an open cvt for about 3 years on my one scooter, that has seen a water hose less than 10 times and ive never experienced this. i guess i have been lucky.
Post by FrankenMech on Jun 26, 2017 23:48:22 GMT -5
All it takes is one hard particle but in this case it is probably more. Maybe he found a diamond mine. I have seen it in belt drives for industrial applications. It really isn't a good idea to run an open CVT. It is also a safety issue, -an errant pants leg could chew up a leg big time.
Post by dexameth on Jun 27, 2017 6:02:42 GMT -5
All it takes is one hard particle but in this case it is probably more. Maybe he found a diamond mine. I have seen it in belt drives for industrial applications. It really isn't a good idea to run an open CVT. It is also a safety issue, -an errant pants leg could chew up a leg big time. Yeah but pants... In Florida? Ha! But on a serious note, I want to run a vent tube from the fan to the front of the CVT cover to help with forced cooling.
Post by FrankenMech on Jun 27, 2017 20:14:32 GMT -5
Yeah, pants are needed in Florida. Road rash is very unforgiving.
Anything you take away from the fan before the engine fins reduces engine cooling.
I have a warm air tube from my engine cover, after the engine fins, to my pod filter for warm air induction to help prevent carb icing, which can even occur in Florida.
I also have an air scoop on my CVT intake to bring in cold air from in front of the engine.
Post by jeff84 on Jun 27, 2017 21:04:38 GMT -5
All it takes is one hard particle but in this case it is probably more. Maybe he found a diamond mine. I have seen it in belt drives for industrial applications. It really isn't a good idea to run an open CVT. It is also a safety issue, -an errant pants leg could chew up a leg big time. they don't call it an ankle biter setup for nothin also liquid cooled ftw
Post by humanshield on Jun 27, 2017 22:35:40 GMT -5
No clue what did that but.....it would probably only take one little piece of steel or something getting stuck in the belt considering it goes around so many times.
See if a tiny sliver of steel wire got pressed into the belt somewhere? Might be easy to miss.
Dunno. Speculation of course.
