theo547
Post by theo547 on Jun 4, 2011 15:08:56 GMT -5
So i finally got my scooter running properly. then on a test run it totally died, lost all power... ect... Had to kick start it and it started with no problems. Now when im driving it feels like the fork is locking whenever i get any sort of speed. very not safe to drive
Post by ltsride on Jun 4, 2011 16:25:35 GMT -5
need to greese the bearings on the steering shaft and make sure when you tighten the big steering stem nut not to over tighten it
theo547
Post by theo547 on Jun 4, 2011 20:12:47 GMT -5
didnt work ;(
Post by 90GTVert on Jun 4, 2011 20:51:18 GMT -5
If there's nothing hitting or rubbing and the upper and lower bearings for the steering stem are in good condition and greased, I dunno what else it would be?
Post by Fox on Jun 4, 2011 21:08:28 GMT -5
Only happens when up to speed?
Grab the front wheel and see if it spins easy and check for play in the bearings/axle by trying to wobble it side to side.
Post by marshinman on Jun 5, 2011 7:30:25 GMT -5
Check the ignition switch and see if the steering lock is causing the problem.
