Dogbite
Chinese scooter Hacker
Post by Dogbite on Jul 1, 2017 19:51:49 GMT -5
Dogbite
Post by Dogbite on Jul 2, 2017 8:11:23 GMT -5
Big bore kit is done now time to see if a old long case ,long shaft will fit in shortcase frame.Does anyone know if there are rubbing issues or other issues with putting a 13 inch wheel with a frame made for 10 inch wheel.
Dogbite
Post by Dogbite on Jul 5, 2017 8:03:23 GMT -5
Floorboard is in and most of the body work and flat backing clips.Bike was not starting, just clicking , I looked at the starter,after replacing the solenoid and it still just clicked. I plugged in the starter and it still just clicked. I checked the wire leads to the starter and found the black and red leads ( male and female) were going black to red and red to black. I re pinned the wires so they go red to red and black to black. So lesson learned allthough the plug is univerasal and you could use a random wire, you still need to look at the wires going through the connector to make sure the wire colors are the same on both sides. With wires correct bike starts right up.
Dogbite
Post by Dogbite on Jul 7, 2017 20:58:53 GMT -5
Ok bike starts and runs smooth but,sounds horrible when starting.Tracked down bad noise coming from bendex area.There is no bendex bushing on kick start cover. I will dig one up out of an old broken one.
Post by dan50 on Jul 8, 2017 1:44:08 GMT -5
Looking GOOD!
Dogbite
Post by Dogbite on Jul 8, 2017 7:33:30 GMT -5
I got the starter bendix bushing in and it starts smooth. Next need to find another center stand. The correct stand for the enegine has it sitting real high and with the slightest touch it will roll forward onto the ground.I also need a rear rack ,the one I have does not line up. Need to play with jetting and needle on carb,part throttle hesitation at low speeds.
Post by greggkinney on Jul 8, 2017 21:37:30 GMT -5
damnit man!!! that dont look like spare parts to me lol nice
