Post by Delpzie on Nov 14, 2017 11:20:17 GMT -5
Winter is near so scooter is garaged, i put the new radiator everything is in place no any problems but havent driven to check temps, also got the engine out and will take it to VlatX he will try to make subframe, if we dont succeed then i will buy the stage6 subframe which will cost me a lot because of shipping, taxes....
Post by spaz12 on Nov 14, 2017 11:32:07 GMT -5
Winter is near so scooter is garaged, i put the new radiator everything is in place no any problems but havent driven to check temps, also got the engine out and will take it to VlatX he will try to make subframe, if we dont succeed then i will buy the stage6 subframe which will cost me a lot because of shipping, taxes.... Don't buy the Stage6 subframe, it's designed for the Aerox frame (not just the motor) and 99% chance that it won't fit your scoot frame. Look near the last page of "H2o Conversion" thread and there are some good pics of a custom subframe. You won't use those exact measurements, but it should give you a good idea how yours should be made.
Baotian
Nov 14, 2017 11:34:34 GMT -5
Post by spaz12 on Nov 14, 2017 11:34:34 GMT -5
Baotian
Nov 14, 2017 12:14:06 GMT -5
Post by Delpzie on Nov 14, 2017 12:14:06 GMT -5
Thanks for pointing out that, but i think my frame is same as the aerox one, might be little diffrences maybe not sure.
Baotian
Nov 14, 2017 12:28:14 GMT -5
Post by pinkscoot on Nov 14, 2017 12:28:14 GMT -5
Damjan that is one hot scooter you have.
Post by vlatx on Nov 14, 2017 13:12:34 GMT -5
The engine is going straight to Vestech Garage and it will have custom subframe made by VlatX (me)
Baotian
Nov 16, 2017 13:59:46 GMT -5
Post by Delpzie on Nov 16, 2017 13:59:46 GMT -5
Since i will be getting soon 28mm pwk carb firstly i wanna buy sets , can u tell me from which to which number to get mainjet, slowjet, powerjet , for the needle set i want to buy the polini set , i will use the carb on this cylinder with open filter it will be polini big evo filter or the stage6 double layer.
Baotian
Nov 16, 2017 15:21:23 GMT -5
Post by spaz12 on Nov 16, 2017 15:21:23 GMT -5
Since i will be getting soon 28mm pwk carb firstly i wanna buy sets , can u tell me from which to which number to get mainjet, slowjet, powerjet , for the needle set i want to buy the polini set , i will use the carb on this cylinder with open filter it will be polini big evo filter or the stage6 double layer. The go-to needle is the JJH, which many of us here use and it works great for me. My jetting is a 52 slow jet and somewhere around 140 on the main. That's for a 77cc and all sorts of different parts, but I think you can probably start there and go down.
Baotian
Nov 17, 2017 6:11:14 GMT -5
Post by Delpzie on Nov 17, 2017 6:11:14 GMT -5
Since i will be getting soon 28mm pwk carb firstly i wanna buy sets , can u tell me from which to which number to get mainjet, slowjet, powerjet , for the needle set i want to buy the polini set , i will use the carb on this cylinder with open filter it will be polini big evo filter or the stage6 double layer. The go-to needle is the JJH, which many of us here use and it works great for me. My jetting is a 52 slow jet and somewhere around 140 on the main. That's for a 77cc and all sorts of different parts, but I think you can probably start there and go down. Thank you man , also about the powerjets i think to buy the lowest number set 30-40 its okey i think?
Baotian
Nov 17, 2017 14:03:22 GMT -5
Post by spaz12 on Nov 17, 2017 14:03:22 GMT -5
I have no idea about the powerjet. I'd say check out other peoples builds and see if they mention a number in their signature.
And I was thinking this morning that I'm closer to 142-144 on my main and that that is warm weather jetting. Now that it's getting colder I would be going up on the jetting.
Post by Delpzie on Dec 11, 2017 11:00:39 GMT -5
Baotian
Dec 11, 2017 11:47:51 GMT -5
Post by aeroxbud on Dec 11, 2017 11:47:51 GMT -5
That should flow better 😀
Post by Delpzie on Dec 14, 2017 14:08:14 GMT -5
Post by Delpzie on Dec 20, 2017 13:17:05 GMT -5
Baotian
Jan 29, 2018 18:06:38 GMT -5
Post by Delpzie on Jan 29, 2018 18:06:38 GMT -5
Its been a while, i got the engine from VlatX , meanwhile i bought fast throttle and im waiting for my exhaust wrap to arrive and im putting it back on.
I wanted to ask you guys about the top performances TPR 86cc kit , the full pack with crankshaft and kit is not expensive and it seems to be good , they declare it as hyper racing kit, what do u think will it make 22-25hp at the wheel (with all needed componentes ofc) , its good option and cheaper for me to get.
