Post by spaz12 on Nov 13, 2017 20:49:46 GMT -5
Crazy that Tsimi in Japan got his package before you did. Glad you like the fender.
Post by spaz12 on Nov 22, 2017 19:40:02 GMT -5
It's been 10 days now and I'm running low on popcorn
Post by PIG on Nov 22, 2017 20:20:12 GMT -5
The carb should be here any day. As for the intake, I have no idea. I’m going to email scootertuning and see what the deal is.
Post by PIG on Nov 24, 2017 11:58:44 GMT -5
So I ordered the 2fast intake but when scootertuning checked to see if a 35mm Keihin would fit, and it never. So I’ve had to switch my order to the MXS intake which lucky they already had one on order so I should get it next week sometime. The MXS looks to be a better intake anyways, I just don’t like the green colour. Maxiscoot gives a good description of the intake. www.maxiscoot.com/mxs-racing-intake-kit-highflow-minarelli-horizontal-mxs-012-3.html
Post by spaz12 on Nov 24, 2017 15:24:17 GMT -5
So I ordered the 2fast intake but when scootertuning checked to see if a 35mm Keihin would fit, and it never. So I’ve had to switch my order to the MXS intake which lucky they already had one on order so I should get it next week sometime. The MXS looks to be a better intake anyways, I just don’t like the green colour. Maxiscoot gives a good description of the intake. www.maxiscoot.com/mxs-racing-intake-kit-highflow-minarelli-horizontal-mxs-012-3.htmlHoly hell that intake is expensive!
Post by PIG on Nov 24, 2017 16:59:19 GMT -5
Ya these 33-35mm Keihins are a really pain in the ass and wallet. If I would’ve went with a Stage6 clone PWK in the same size the smaller intakes would’ve worked. They have the same size bodies as the 28mm Keihins, not sure how that works??? The route I went is definitely more money, but there’s no compromises and it should flow like a mofo. I still might send my cylinder to HK racing and have them do there magic on it. I want this thing to be f-ing crazy.
Post by drc174 on Nov 24, 2017 17:41:58 GMT -5
Definitely butt test the shiz out of it. I’ll probably use the 28mm just to get it started. Then around the end of the year step it up to a 35mm like yourself. I only had $165 cash on me today when I went into scooterswapshop. But I put the spacer and reeds on layaway. 😆 He sent me home with the spacer. I’ll pick up the reeds next payday. If I had the 35mm keihin now I would have saved the brand new 28mm for later.... How much you paying for the reeds? you can get a set of two for 189
Post by 'O'Verse on Nov 24, 2017 21:27:37 GMT -5
Definitely butt test the shiz out of it. I’ll probably use the 28mm just to get it started. Then around the end of the year step it up to a 35mm like yourself. I only had $165 cash on me today when I went into scooterswapshop. But I put the spacer and reeds on layaway. 😆 He sent me home with the spacer. I’ll pick up the reeds next payday. If I had the 35mm keihin now I would have saved the brand new 28mm for later.... How much you paying for the reeds? you can get a set of two for 189 I got both intake and reeds for $200.
Post by drc174 on Nov 24, 2017 21:33:11 GMT -5
Decent!
Post by 'O'Verse on Nov 24, 2017 22:04:06 GMT -5
I did get the box that the two original banshee reeds came in and all its hardware. Like 4 gaskets, 8 screws, 4 stickers, and the free license plate!
Post by PIG on Nov 25, 2017 11:30:47 GMT -5
I’m also going to be switching to a duel radiator setup. I’ve never had heat issues but with all these new expensive parts a little extra insurance never hurts.
Post by AtariGuy on Nov 25, 2017 11:44:51 GMT -5
I’m also going to be switching to a duel radiator setup. I’ve never had heat issues but with all these new expensive parts a little extra insurance never hurts. Are you adding a second rad or replacing it with a pair? If so, what are you doing with the old one? Selling it to me? (Wink)
Post by PIG on Nov 25, 2017 12:11:42 GMT -5
I’m also going to be switching to a duel radiator setup. I’ve never had heat issues but with all these new expensive parts a little extra insurance never hurts. Are you adding a second rad or replacing it with a pair? If so, what are you doing with the old one? Selling it to me? (Wink) I’m adding a pair, and selling the other one. Shoot me a pm and I’m sure we can figure something out.
Post by 'O'Verse on Nov 25, 2017 12:19:44 GMT -5
Yes. It's no longer $200 singular parts. We're talking $300-$600 each. We're batting a $500 average here. No joke.
Post by PIG on Dec 5, 2017 23:51:27 GMT -5
Still waiting on the carb..................... But everything else showed up today 👍. Stock size Vforce3 reed valve compared to the KX85 Vforce3 valve that comes with the MXS intake.
