Post by Jwhood on Jul 30, 2017 23:11:27 GMT -5
No I said dremmel out the intake rubber tube not that side lol,u need to make an adapter,Brent has "diy" in the tech section on how to modify oem air filter to fit bigger carb check it out
Tgb 101s
Jul 31, 2017 6:16:13 GMT -5
via mobile
Post by baywatch7737 on Jul 31, 2017 6:16:13 GMT -5
Wth is going on with the starter gear I can't get this thing on the crank.
Tgb 101s
Jul 31, 2017 9:41:00 GMT -5
via mobile
Post by baywatch7737 on Jul 31, 2017 9:41:00 GMT -5
I might have to buy a new starter gear? The eBay guys has some for about 16 dollars. I'm worried I'll buy that then have the same problem. Any advice ?
Tgb 101s
Jul 31, 2017 11:01:28 GMT -5
via mobile
Post by baywatch7737 on Jul 31, 2017 11:01:28 GMT -5
I saw on the tgb forum jwhood where you asked oilyhans for springs. Did you get them from him? His prices are crazy. Anyway the malossi spring I got is to narrow to fit the plastic bushing behind the clutch. And I can't seem to find any contra springs made specifically for tgbs.
Tgb 101s
Jul 31, 2017 18:18:50 GMT -5
via mobile
Post by baywatch7737 on Jul 31, 2017 18:18:50 GMT -5
I looked in the service manual, it had the stock clutch bell at 110.something mm. What size clutch do I need to work with that?
Post by Jwhood on Jul 31, 2017 19:19:24 GMT -5
I used top racing springs from racing planet there for a piaggio there small compared to minarelli springs,as for torque springs I used naraku also got them from racing planet in a 2 pack a 1000-1500 Rpm torque spring,as for the clutch still working on that I'm looking for an aftermarket one now
Post by baywatch7737 on Aug 4, 2017 9:11:50 GMT -5
Well j, I found a 22 spline clutch bell on eBay. I been in contact with the guy selling, the parts are coming from taiwan. He's also selling a hp clutch. I might look into those once I get this running.
I almost got it all back together, I had to make a few modifications for the new carb but got it looking right. Realized yesterday I got br9es instead of br9hs, so I gotta go get the right ones today and hopefully I can start it up. Wish me luck guys.
Tgb 101s
Aug 6, 2017 10:25:06 GMT -5
via mobile
Post by baywatch7737 on Aug 6, 2017 10:25:06 GMT -5
Got my bike almost all back together. The throttle cable i ordered from scooter dynasty, the sheath was to long so I tried to Dremel some of the sheathing off. I do not think it will hold up though so I ordered a qj throttle cable on eBay, it was the only one that had the right hook up to the throttle housing. Hopefully it will work.
Tgb 101s
Aug 10, 2017 20:09:12 GMT -5
via mobile
Post by baywatch7737 on Aug 10, 2017 20:09:12 GMT -5
Hey guys, been awhile. Anyways got my scoot mostly back together. Got the keihin jog carb on it. I tried a 95 mj first and worked my way down to an 85 but I still can't get it to run consistently. The revs fluxuates even when I'm holding the throttle wide open and it won't start until I give it some gas. I'm not even sure where to start??
Tgb 101s
Aug 11, 2017 8:59:04 GMT -5
via mobile
Post by ThomasTPFL on Aug 11, 2017 8:59:04 GMT -5
Quadruple check for air leaks?
Tgb 101s
Aug 11, 2017 19:28:47 GMT -5
via mobile
Post by baywatch7737 on Aug 11, 2017 19:28:47 GMT -5
Ok, time to build my leak down tester. I noticed tonight that gas is coming out of the bottom of the carb, also there is some gas, not a lot but some. I'm starting to think I'm having a float/fuel delivery issue.
Tgb 101s
Aug 12, 2017 10:31:01 GMT -5
via mobile
Post by baywatch7737 on Aug 12, 2017 10:31:01 GMT -5
Shoot I meant to say there is some gas in the hose between air box and carb. Not a lot but some, I'm thinking I might have to get a new carb.
Post by Jwhood on Aug 12, 2017 23:58:42 GMT -5
Your petcock might be bad mine was bad just added a fuel shut of valve so when I turn the scoot off I turn the gas off or float is not level in carb
Tgb 101s
Aug 14, 2017 16:40:47 GMT -5
via mobile
Post by baywatch7737 on Aug 14, 2017 16:40:47 GMT -5
Ok guys I got it!! I was just not getting it enough air.i drilled 3 3/8 holes in my stock air box and viola. It's running real good I've been checking my spark plugs lots, running with 90mj needle in the middle. I might try a 95 just to err on the cautious side.
One thing I noticed with this malossi variator is the sleeve that slides on the crank shaft is different from the stock one. The stock one has a lip that allows it to be pushed all the way back to hold the starter gear in place. The malossi sleeve does not hold the starter gear in place, I found out by it slipping off. Once I reinstalled the stock cvt and the stock torque spring it is running great!
I'm gonna be tuning this week in the evenings until I go get it tagged.thank you again everyone who chimed in with there know how. Hopefully soon I'll find a minarelli to build up. I'll post some pics soon. Jw I was thinking of painting mine matte black with a nice dark mettallic orange stripe, did you paint yours yourself?
Post by Jwhood on Aug 14, 2017 22:00:00 GMT -5
Yeah painted mine on my own not the best
