Post by lostforawhile on Jul 27, 2017 20:17:28 GMT -5
is there a how to on a sunni style scooter on removing the front plastic over the wiring? I know there are screws, but i don't know where they all are. I'm getting ready to wire up my lighted reflectors, so I need to be able to access the wiring behind the light, I need to get to the left and right turn signal wiring, and illumination for the running lights next to the headlights, I'm going to make them full brightness, and alternate with the turn signals by using relays. Each reflector light has two circuits , I'll make the harness from the rear reflectors tonight and put it in tomorrow.
Post by humanshield on Jul 27, 2017 21:18:18 GMT -5
The lower plastic has I believe 6 or 8 screws in the back and one in the front near the top.
The upper plastic guard around the speedometer has I believe two at the top and two at the bottom.
In any event......don;'t be afraid to remove the phillips head screws you see. it's safe to remove and they all will go back in. Just don't overtighten them because the plastics tend to break easily.
good luck
Post by lostforawhile on Jul 27, 2017 21:33:20 GMT -5
yea I already made up a nice harness from the back two reflector locations, I already have the seat loose waiting on carb parts, so it's pretty easy to fish it along the frame following the original harness heading to the front. I have to fish this to the front, then two short harnesses from the front two amber reflector locations. then I can wire everything behind the panel, and put in the relays. I Decided to run it off the key VS AC from the stator, so when the turn signals have power, so do the side markers, they are LED so they won't draw much current
Post by lostforawhile on Jul 28, 2017 0:05:17 GMT -5
four screws, piece of cake, then I discover I have a bad light after the harness is IN
