Post by 90GTVert on Aug 19, 2017 7:20:29 GMT -5
If you look in your mini profile (the thing on the left of your posts where your avatar is), you should see "Trader Points". Below that, "Rate Trader" with a + on one side and - on the other.
Clicking the + will add a "trader point" and using the - will take one away.
I have set it so that a member can only change any member's count one time in a week, in hopes of avoiding lots of false ratings.
The idea is to give a positive rating any time you are happy with another member's interaction for a sale or trade. You can use it for buyers as well. Please do not rate someone if you have not had a transaction with them, and please only 1 rating for each transaction. If you were neither pleased or displeased, just don't rate the member.
I cannot set this to only be active in classifieds, so it may accumulate ratings for reasons other than trading and I'm not sure if it will prove to be useful or not. We can give it a shot and see how it goes.
If the consensus now or later is that it is a bad idea or does not work to give any good insight into trading experience, it will be removed. If arguments and/or negativity are occurring because of points, it will be removed.
A member's "Trader Points" are not an endorsement by this forum or proboards and you must still use the classifieds at your own risk.
