Post by ososlow on Jun 15, 2011 11:58:05 GMT -5
OK, so i have one of the new VIP future champions, and Ive read that they have a 44mm piston instead of the 39mm found on most other scoots. so what I'm guessing this means is i have a shorter stroke. so what I'm wondering is if i get a bbk will i need to get a rod to go with it ?
Post by reveeen on Jun 15, 2011 15:02:39 GMT -5
More than likely a 60cc engine. Just order the bore size you want (keeping in mind that some cases will not accept the 80cc kit without boring).
Post by ososlow on Jun 16, 2011 9:34:07 GMT -5
is there a way to tell? i have 1p39qmb stamped on my case.
Post by 90GTVert on Jun 16, 2011 10:02:22 GMT -5
Measure the stroke. Should be 41.4mm.
Post by ososlow on Jun 18, 2011 9:53:45 GMT -5
thanks for the specs. ill check the stroke sometime later, I'm gonna have to adjust my valves in about 150mi so maby ill check it out then. I'm like 90% positive its only 49cc though. all the emissions tags say 49cc, the valve cover is stamped with 49cc.
Post by reveeen on Jun 18, 2011 10:30:51 GMT -5
all the emissions tags say 49cc, the valve cover is stamped with 49cc. You, sir, sound just like a truck driver. In these days of full electronic diesel engines, a mechanic sets the horsepower electronically with his plug-in hand held...... it matters not what it says on the tag. You will never know what exactly is "in there" unless you get "in there" and find out.
Post by 90GTVert on Jun 18, 2011 17:34:09 GMT -5
Lots of scoots come labeled as 49cc and 139QMB that have 44mm bore. The 39 in the 139QMB designates bore diameter, so that alone should tell you all you need to know about trusting Chinese specs and paperwork.
