Post by Reign on Dec 2, 2009 14:49:01 GMT -5
Post by 90GTVert on Dec 2, 2009 15:47:36 GMT -5
That should work. The E-ton, Dinli, etc... 90's they list are minarelli style 2Ts just 90cc like the one in my 2nd Triton.
Post by Reign on Dec 2, 2009 15:59:24 GMT -5
Ok cool. Comparing images with a TM24 I found on sipscootershop, the only real difference I see is this extra port, as well as the machined away intake side:
Post by 90GTVert on Dec 2, 2009 16:20:41 GMT -5
The smooth inlet might make mounting a little harder, but I'm sure you could figure some sort of adapter out if necessary. Not sure what the extra port is. 2nd fuel inlet? Not sure. Ask the seller.
Post by Reign on Dec 2, 2009 22:33:51 GMT -5
seller says its a secondary fuel line, it bypasses the one on top of it, and actually cuts it off. It's machines down from 31mm stock on the intake side to 28mm after. So where can I find a 28mm intake?
Post by Fox on Dec 3, 2009 12:38:16 GMT -5
