Post by 1quikvento on Jun 16, 2011 23:01:23 GMT -5
:help: Okay- Ive been following another members thread about his bulb issues. Like him, I am having problems with my 2004 vento triton R4 blowing bulbs/overcharging. This is the first 2-wheeled motorized vehicle I have ever owned and so far I havent been able to take it out for its intended purpose. Im not completely dumb when it comes to diagnostics. Ive been an auto mechanic for 12 yrs or so, but I gotta admit that perhaps my weakest area is electrical issues. Strangely enough that only a handful of cars I've diagnosed/ worked on had electrical problems and I happen to buy a used moped that ends up being riddled with them!!(Bought from my boss nonetheless!!)
So heres a little background info that will help you help me. The scoot has 1350-1400 miles on it.Boss said during purchase that it kick starts up fine-runs fine. That turns out to be true. Also said that one day he noticed smoke coming from what he thought was the digital clock area, so he simply removed that clock from the gauge panel-no biggie to me. Lastly that I would need a headlight bulb and tail bulb. Boy did I ever(been thru 3 of each so far).
I had to buy a battery for it cuz the one supplied would not take a charge. My diagnostic tester detected a short between plates(bad cell). I also had to replace ALL the light bulbs. Except for the ones in the gauge cluster, they were all blown. Got back home from my first trip out and the bulbs went out again. I made some calls, did a lil research and decided to try out a different voltage regulator/rectifier based on others' experience I've read about a combined piece of advice.
I dont know if it was used or new but it didnt help. next I removed 75% of all the fairings and body panels. I cut some zip ties to let the harness breathe some and fiddled with some connectors hoping there was a fault somewhere. And suddenly i made some progress- the bulbs would no longer get super bright and blow as rpm's picked up like before. But now my volt meter was telling me that the battery was being overcharged. I'd get an initial reading of 13v at the battery terminals and as I let it sit and idle, voltage would slowly creep to about 15.5v. And while opening the throttle say 50-75% I would get a reading of 17-19volts.
Next:
I picked up a used regulator from a local guy just for shits and giggles because after reading thru as many 49cc forums as i could find- the thing that stuck in my head most was SOOOOO many people say its hard to find a good reliable working regulator and that its one chinese part that has a high failure rate.
So my other regulator doesnt blow the bulbs anymore, but overcharges the battery. Can anyone guess what this new used one does?? ready?? It blows the f'in bulbs but charges the battery!!!
So Im out about 50 bucks in bulbs and I got an Andrew Jackson wrapped up in regulators. Can anyone offer me an explanation?
I read about people trying to switch the headlight power supply from ac to dc by taking the green/red wire from the regulator and undo that wire at the right headlight switch and tie it in to the red/white wire going to the horn which supplies 12vdc with ignition on. Sounded like a brilliant idea to me since supposedly it converts the taillight circuit to dc as well. Does anyone have good experience with this method?
And I came up with my own little idea to remedy the situation and I need someone out there to tell me if theoretically it will or will not work: I got two regulators. one overcharges and doesnt blow bulbs while the other charges well but blows bulbs. Would it work if I installed both regulators? What i have in mind is taking apart the plug and send the wires responsible for charging my battery to the one regulator that seems to charge ok, and run the other two wires to the regulator that keeps my bulbs in check? Two regulators-two wires running to each- both have their own job to do. ...
SO .. can anyone relate to my problem and/or help me out? Will my dueling regulator set up work? OHHH!!! I'd like to bring something up that might help someone out there that I dont see mentioned ANYWHERE!!! that is totally relevant when working with these regs/rectifiers. I wouldnt have known better- but the guy who sold me the used regulator told me that it absolutely had to be bolted to the frame so it grounds out in order to work correctly. True or not?
Help!!
Next:
Help!!
