loosegrit
Too much work. Hope for another scooter run Oct 2015.
Post by loosegrit on Jun 18, 2011 15:31:29 GMT -5
This was done on a 49 cc Jonway scoot after breaking a shock. All it took was two shocks the same size, washers as spacers and 1 each 10 x 1.25 x 80 for top and 8 x 1.25 x 80 bottom and a little tiime. Second set of hands are very helpful. If you like the plastic back on just cut enough for the second shock.
Post by 90GTVert on Jun 18, 2011 15:50:06 GMT -5
It's a shame there's no cheap and easy way to use a shock on each side. Nice fix. That oughta hold. I'd think at that point the weakness would be the long bolts, so just make sure they're good grade / hardened.
Post by jmkjr72 on Jun 18, 2011 16:09:13 GMT -5
Post by jmkjr72 on Jun 18, 2011 16:43:31 GMT -5
you can realy make a bottem mount that is a lot stronger if you get some small dom tube to use as spaces between the 2 shocks and in the bottem u of the outer shock then hook that all together with some flat iron then use a bit more dom to space out from the two bolt holes near there and tie that into the other part of the brace i put some orange marks in the pic just to give you an idea then up top i would space it out with dom and then add 2 extra tabs to the frame and bracket them together
loosegrit
Post by loosegrit on Jun 18, 2011 20:31:20 GMT -5
Thanks, I just order the better lower bolt and will replace as soon as it comes in. And will try the spacing. This was my first try. You guys make a good sounding board for my ideals. Thanks again.
