Post by 190mech on Oct 11, 2017 16:50:22 GMT -5
2 strokes SHOULD smoke!Just disconnect that secondary air stuff,will likely need some rejetting and CVT work done to get it happy..
Post by benji on Oct 11, 2017 17:12:56 GMT -5
It should definitely smoke more w a new pipe haha. Sometimes the stock pipes get clogged up and smoke less due to restrictions n clogs.
sitht
Scoot Junior
Post by sitht on Oct 11, 2017 21:21:09 GMT -5
Thanks for the feedback guys. I did change out the main jet today. 190mech on the secondary air supply I can rip out the last hose, do I just plug the hole then? If so what do you recommend i use?
Post by 190mech on Oct 12, 2017 4:03:11 GMT -5
Right,just remove the hose and cap the end fitting,just in case you may need to reinstall the stock stuff some day..
