Post by amazen720 on Oct 16, 2017 12:02:45 GMT -5
okay guys I'm new to scooters.. This scooter been siting since 2013.. I cleaned the carb, cleaned the gas tank.. scooter cuts off after a few secs, only starts if I give it throttle, and when riding and throttling oil light comes on and the it boggs down... when I open manual choke bike revs and then cuts off... any help?
Post by 190mech on Oct 16, 2017 12:07:43 GMT -5
Carb not clean enough,,choke circuit clogged,check the injector oil level,You have a DC CDI which requires a good fully charged battery.. Hope this helps!
Post by tortoise2 on Oct 16, 2017 12:22:24 GMT -5
If reeds are in good shape . . might try a test start with a slight gap between cylinder and exhaust flange, to rule out a carbon, rust, nesting insect obstruction.
Post by amazen720 on Oct 16, 2017 12:23:06 GMT -5
Thanks for the reply... So the choke hole is clogged? I took out all the jets and soaked them in gas... Do you think I should remove the gas tank and thoroughly clean it? It has a gas filter and gas seem really clean...
Post by amazen720 on Oct 16, 2017 16:27:00 GMT -5
Super cleaned the carb... still I get oil light when I ride at half and full throttle, if I hold the throttle on up hill it will bogg out, down hill I get a popping sound... any suggestions?
Post by 190mech on Oct 16, 2017 17:07:41 GMT -5
Oil light is a level indicator in the oil injection tank,,The choke(enricher) orifice is a tiny hole usually drilled in the float bowl to feed the copper standpipe of the enricher..I'll dig up a pic if you cant find it...
