Post by jdl357 on Oct 17, 2017 20:42:32 GMT -5
Found a set of cases labeled GE1E40QMB. Looks like it's set up for rear disk. Otherwise looks like a 1e40qmb. You guys familiar with this?
Post by moofus02 on Oct 18, 2017 0:03:31 GMT -5
Picture?
Post by jdl357 on Oct 18, 2017 9:42:58 GMT -5
Post by pinkscoot on Oct 18, 2017 9:56:42 GMT -5
Here is a scooter for sale with the engine in it, and another. Google it and you'll find lots of info, all in Europe so you'll need to translate.
Post by benji on Oct 18, 2017 10:24:05 GMT -5
Looks like a generic version of a disc brake minarelli motor, commonly found on aerox's and Jog r scooters in Europe.
Post by benji on Oct 18, 2017 10:24:15 GMT -5
Good find
Post by benji on Oct 18, 2017 11:00:53 GMT -5
Also, that motor has the tranny cover mounted on the out side instead of inside the CVT cover behind the td. Looks like my cpi long case except disc brake.
Just took a look at my cpi case. It's a qj1e40qmb, but it looks alot like the motor you got here. It's not disc tho.
Post by moofus02 on Oct 18, 2017 11:09:28 GMT -5
The difference with the disc cases in the clones is the disc brake caliper mount is on the external gear cover
Post by benji on Oct 18, 2017 11:09:56 GMT -5
Here it is. Long case Quang jang Mina, shortcase CVT, 12mm piston pin, big spline crank, outside trans cover. Rear drum 110mm brake
Post by 90GTVert on Oct 21, 2017 9:37:56 GMT -5
Just looks like a typical 1E40QMB long case to me. Without the small case half of the gearbox, I don't know how you'd determine that it's intended for a disc brake. My guess is the GE is a manufacturer code. Like a QJ1E40QMB is made by Quianjiang. Not sure who GE is.
