Post by drbob on Oct 20, 2017 15:58:29 GMT -5
Seems like once the enricher shuts off my takeoff bogs like crazy and then picks back up. When i leave and enricher is o. Take off is perfect. Not sure how to remedy. Tried a/f mix and nothing cha ges with take off
Post by 190mech on Oct 20, 2017 16:17:56 GMT -5
Try richening your jet needle(lowering the clip/raising the needle),that should help,,
Post by drbob on Oct 20, 2017 16:25:30 GMT -5
That accually makes sense. Im pretty sure when i just put my old carb back on i did lean it out. My needle had 5 notches and was centered but i went up a clip to leaner. I had the issue before slightly so maybe ill go down 1 from where it was originally to richen more. Didnt need to upjet main when i got my tecnigas next pipe. But i guess where the powerband kicks in mid throttle may need richened
Post by jackrides on Oct 20, 2017 22:11:37 GMT -5
Have you accessed the idle mixture screw? A quarter turn richer might help.
