Post by asources on Jun 21, 2011 11:53:16 GMT -5
Good day What would be the best air filter model that i can put on this model ? Does anybody know a model for this scooter ? Also what would be the jet for this with the new air filter ... #82 #84 #85 ... I dont have the tools to measure size of airfilter ... ;( If i change the air filter for a new one ... what do i have to do with all the hoses plug to the air box ?? I noticed 3 hoses ... 1 pink color that goes nowhere ... 1 black that goes under around the motor ... not sure where exactly ...( did not open anything ) and the last one goes down to ( i think the transmission ) ... Im new into this
Post by 90GTVert on Jun 21, 2011 12:04:23 GMT -5
:welcome: Most people go with a 38mm ID (1.5") UNI filter and 85 - 90 main jet. The pink hose going nowhere would be a drain. It can leave with the stock airbox. One hose should be a crankcase vent, CLICK HERE for more info on that. I think you can ditch the other, but make sure you trace where it's going first.
Post by asources on Jun 21, 2011 12:22:50 GMT -5
Thanks for the answer ... appreaciated ...
What would be the best choice ... in the jet 85-90 ...
Post by 90GTVert on Jun 21, 2011 12:31:03 GMT -5
88 is what Enviromoto sells to go with his UNI filter for the GY6 50. He's got a lot of experience with them, so if I had to pick just one it would be the 88.
Post by asources on Jun 21, 2011 13:17:07 GMT -5
Great but if i cut and use the hose that comes on the stock air box for this people s 50 2009 do i still need 38mm filter ??
