Post by ancusza on Dec 8, 2017 11:51:18 GMT -5
Help!!! Fuel gauge on the dashboard does not move! I put gas and indicator it's only in Empty! I do not know what to do!
Post by tortoise2 on Dec 8, 2017 12:01:09 GMT -5
I do not know what to do! It would require some initiative on your part, but one strategy is researching YouTube videos.
Post by islandscrub on Dec 8, 2017 12:24:49 GMT -5
Check your wiring connectors and make sure they are in good. Fuel gauge usually connects to the harness at the rear right of the scooter. There should also be a connector up front behind the headlight, check there too. If its not those you may have a stuck float arm (inside the tank) or the gauge just went bad.
Post by twitchytoes on Dec 8, 2017 15:05:13 GMT -5
I've had one of the wires that has an o clamp on it around the screw come loose on my dash before, that's something I'd look for.
Post by aeroxbud on Dec 8, 2017 15:26:04 GMT -5
If you bridge the two wires to the sender at the fuel tank, the gauge should move to full. If it does this then the likely problem is the fuel sender. If the needle still does not move, it is either the gauge, or wiring.
Post by greginisn on Dec 8, 2017 20:54:20 GMT -5
The in tank float can sometimes get a leak, fill with fuel & sink. No reading.
loads of good tips here tho.
Greg
