puta
Post by puta on Dec 10, 2017 11:31:18 GMT -5
I have another problem with my scoot... every time im going to start, it wont start... i tried to inspect the sparkplug and i saw that the spark plug was full of not burnt gasoline so i clean it and plug then.. start but again it does not work... then i unplug again the sparkplug to see what happen... then i saw another not burnt gas so i decided to test my spark plug and to see if does not producing spark.. then when i go starting i saw that it does not producing spark even a blink of spark... so what do you think guys.. thanks for the answers...
Post by benji on Dec 10, 2017 12:43:09 GMT -5
Ignition system problem. Follow the plug wire to the coil, try replacing the coil if you have another lying around. What kind of scooter is this?
Post by pinkscoot on Dec 10, 2017 15:14:20 GMT -5
Here is Brents wont start thread from the Directory in the floating menu on the Left.
puta
Post by puta on Dec 10, 2017 23:52:30 GMT -5
Hi benji thanks for your answer... this is yamaha ca50/beluga... what else is another condition aside for replacing the coil.. is there anything else
Post by benji on Dec 11, 2017 2:09:21 GMT -5
Try cdi, then ignition pickup. I think there's a thread in the tech section on this one.
Post by benji on Dec 11, 2017 2:09:50 GMT -5
Here is Brents wont start thread from the Directory in the floating menu on the Left. yup here's a good one right here. Go down to section 9.
puta
Post by puta on Dec 12, 2017 6:29:17 GMT -5
Here is Brents wont start thread from the Directory in the floating menu on the Left. yup here's a good one right here. Go down to section 9. Thanks a lot!!
Post by lostforawhile on Dec 13, 2017 23:12:17 GMT -5
have you fixed the bent rear wheel? it's probably shaken everything loose,including all the electrical connections
