Post by lilpinny on Aug 11, 2019 10:48:20 GMT -5
No scoot action here. Been preparing for the onslaught though, buying parts, cleaning shop, making a table... Soon! I have the basic stuff, but is there anything you guys got and wished you had years ago? Im in full on nesting mode. KON-TIKI I wished I would have cleaned up my workspace everyday when I was done for the day instead of saying I'll sweep it up later... a pneumatic lift or at least an easy reliable way to get the scoot off the ground and a hand held impact gun.
Post by pinkscoot on Aug 11, 2019 10:57:00 GMT -5
One of my early purchases was a lift, the $300 on sale HF one has done me well. My knees and back have thanked me. I use it for everything including fixing anything that would make me bend over.
Post by Happypancake! on Aug 11, 2019 16:09:56 GMT -5
Balls...we miss you
Post by lilpinny on Aug 11, 2019 17:40:12 GMT -5
One of my early purchases was a lift, the $300 on sale HF one has done me well. My knees and back have thanked me. I use it for everything including fixing anything that would make me bend over. My HF lift broke in the up position with my bike on it. It never worked well to begin with and that was the final straw.
Post by pinkscoot on Aug 11, 2019 17:58:24 GMT -5
Thank you for the warning. I should keep a ramp around in case mine fails.
Post by Tanuki on Aug 11, 2019 19:11:55 GMT -5
Thanks guys! I have about 3 ramps around. Lots of room now! Almost secured enough to bring my tools in. Somebody suggested I needed pin ups. So, here’s my first pin up
Post by Tanuki on Aug 16, 2019 18:35:38 GMT -5
Here we go! Plans are to split the case, replace fucked kickstart gear, inspect the rest, replace clutch and fly side seals, reassemble and test. Then install Polini 177 cylinder kit and exhaust, oko28 carb, cross fingers, and ride! Got most parts and tools needed I think Still need to find throttle cable Maybe find choke cable kit too So far I’ve emptied fluids and that’s it
Post by Tanuki on Aug 18, 2019 23:45:40 GMT -5
Pulled it! Of course that led to another $30 order in random bits from scooter mercado. Then I failed at making a stand. Will try again next week. Check out my coil wire!
Post by spazter12 on Aug 19, 2019 3:13:39 GMT -5
I may need to make a stand like that at some point in the near future for a piranha 140 engine. And that coil wore looks like it's seen better days lol
Post by Tanuki on Aug 23, 2019 4:32:20 GMT -5
Boy 0 boy Turns out ive got a 3 port motor with a 2 port cylinder. My kickstarter gear was missing a spring. Need a clutch holder tool. And my construction crew got blamed for stealing $300 in avocados... Goodnight
Post by aeroxbud on Aug 23, 2019 4:38:12 GMT -5
Busy day 👍
Post by Tanuki on Aug 29, 2019 23:09:23 GMT -5
Going premix
Post by lilpinny on Aug 29, 2019 23:14:12 GMT -5
Automix like me and bones!
Post by Tanuki on Aug 30, 2019 1:17:45 GMT -5
Nope! This is my fuckaround scoot! ARMAGEDDON HERE I CUM!
Post by aeroxbud on Aug 30, 2019 2:42:28 GMT -5
The Vespa auto lube is supposed to be one of the best around. There are big debates on some of the Vespa forums. Some getting very heated! I'm with you though, premix is the safest option.
