Post by Tanuki on Sept 3, 2019 22:53:16 GMT -5
With this is annoying. Holes are gone need some work to fit,
Post by Tanuki on Sept 28, 2019 17:07:54 GMT -5
Post by Tanuki on Sept 28, 2019 17:22:14 GMT -5
Never mind Asshole
Post by Tanuki on Sept 28, 2019 20:24:58 GMT -5
You know, I thought it was too tight
Post by Happypancake! on Sept 28, 2019 21:30:28 GMT -5
Correct Torque is your friend
Post by Tanuki on Oct 1, 2019 2:36:02 GMT -5
Clutch side done, OKO28 mounted, cylinder in....NOOOOOO!!! Whats wrong with reusing 45 year old cylinder head studs?
Post by Tanuki on Oct 5, 2019 11:58:09 GMT -5
Ok now. New studs in. Same thing happen. Excuse me while I bash my head in.
Post by Happypancake! on Oct 5, 2019 12:19:30 GMT -5
How
Post by woodini on Oct 11, 2019 18:26:34 GMT -5
You can do it
Post by Tanuki on Oct 16, 2019 1:23:57 GMT -5
3 tries and boy
Not only were the studs stripping, last try I heard two loud pops right over 10 lbs torque
Looks like case threads on clutch side are both stripped or worn. I think the pop was them pulling out
Im sooo bummed
Post by 190mech on Oct 16, 2019 4:02:22 GMT -5
HeliCoil time!
Post by aeroxbud on Oct 27, 2019 17:36:41 GMT -5
That sucks. With studs, it seems sometimes you get lucky. Other times, not so
Post by christopher on Oct 28, 2019 5:38:04 GMT -5
I’ve used HeliCoils for thread repair in aluminum previously. Actually held up better than the factory aluminum thread. Any experience in a case? How do they hold up, just curious for future reference just in case.
Post by Tanuki on Oct 28, 2019 12:00:35 GMT -5
Thanks for the thoughts, fellas. Im waiting on new studs. I havent decided if i should helicoil a m7 or tap case to fit m8 studs. Another friend mentioned time-sert. Do i tap all 4 to match? Leave the fly side case as is? For she sits covered up in a dark corner.
Post by aeroxbud on Oct 28, 2019 15:29:46 GMT -5
Time serts are supposedly stronger. But helicoil is what most seem to go for.
