Post by Tanuki on Dec 22, 2019 19:42:25 GMT -5
Clutch back together, stator, flywheel, look at wires and ... Remove flywheel, stator, will attempt minor rewiring ... 45 year old shit rules!
Post by Happypancake! on Dec 22, 2019 20:26:41 GMT -5
Clutch back together, stator, flywheel, look at wires and ... Remove flywheel, stator, will attempt minor rewiring ... 45 year old shit rules! Agreed. The older the better
Post by Tanuki on Dec 29, 2019 0:14:33 GMT -5
Rewire stator, flywheel on, rear hub and wheel on, kicker on, test clutch.... No clutch
Post by Tanuki on Dec 31, 2019 20:45:16 GMT -5
Maybe the clutch needs oil...I don’t know. Took the cover off, it looks everything on place.i pushed it in, plunger still there. Pass Installed gear selector Wired coil GOT SPARK!!!!
Post by lilpinny on Dec 31, 2019 21:41:10 GMT -5
W00t!
Post by Tanuki on Jan 1, 2020 23:47:50 GMT -5
Hung a fuel box on the ceiling 132 mj 48 sj 8 puka emulsion tube On the oko28 All guesses Started on 2nd kick Forgot to make a kill switch, will do before I GET carried away Then it’s figuring out timing Then back to jets I’m sure Oh that sweet smell filled the ton-tiki real quick!
Post by lilpinny on Jan 2, 2020 0:24:15 GMT -5
I'll smoke what he's smoking!
Post by Tanuki on Jan 10, 2020 3:24:14 GMT -5
Post by Tanuki on Jan 20, 2020 4:16:14 GMT -5
Post by Tanuki on Jan 25, 2020 21:14:58 GMT -5
I guess paint doesn’t dry on rubber strip things?!!! Damn
Post by Happypancake! on Jan 25, 2020 21:59:34 GMT -5
I guess paint doesn’t dry on rubber strip things?!!! Damn Just put a sticker on it
Post by Tanuki on Jan 31, 2020 2:16:57 GMT -5
I think I didn’t stir the can☹️before painting Back to the engine sitting on a stand, noticed the timing was wonky between rejetting and this Washer for stator screw broken And Scratch marks in the flywheel. Going to ace for new hardware tomorrow
Post by Tanuki on Feb 15, 2020 0:25:15 GMT -5
Did a pressure test It’s an air leak Should have used the copper gasket goober
Post by Tanuki on Mar 14, 2020 14:17:24 GMT -5
2STROKE MOSQUITO SMOKE
Post by Tanuki on May 19, 2020 2:10:43 GMT -5
SCOOT DIARY 2020 Update from the apocalypse
The Hondas:
Balls running, needs valve adjustment, what happens when theres no shim left to shave?
Passport probably should be boxed up for the long sleep, cryogenic suspended animation, wake her in 2035 when we reach the the shores of uranus
Spree is on the operating table and out of anesthesia mid procedure screams at me yet I turn away leaving her in misery
The Vespas:
Grace Jones, the gazelle, wants the adventure scoot life, needs all terrain tires, maybe a rear rack.
Bodgezilla 200, 57 years old and...wow. Needs new wheels before the 15 year old shinkos kill me. I drained the castor bean and dosed her with royal purple yesterday.
King Ghidorah 177 , man o man...redo
