Post by AtariGuy on Jan 18, 2019 15:24:50 GMT -5
Cant remember where i left off, but its apparent i need to open a service shop.
03 forester - valve cover gaskets, radiator flush, waterpump, and rotors/pads/calipers all around.
01 grand am - ignition switch (and tumbler + reprogram keys), starter, battery, ground strap to the engine, exhaust splice ahead of the o2 sensor.
06 trailblazer - front wheel bearings, cv axlesn front brakes, 4 new rubbers, gritblasted and painted the spare rim, new rubber and balanced, vct solenoid, plugs, and map sensor - ordered a set of front coil springs, will be fitting them feb 2nd.
03 trailblazer - brakes, plugs, coilovers, vct solenoid cleaned, map sensor, and blower fan
97 grand cherokee - in the works - alternator blew the RR circuit diodes, very high ac voltage everywhere. This right after it came back from a shop that "fixed" something electrical. (I reeeeeally hate electrical work)
16 cruze - maintenance stuff, oil change, coolant flush, rotate tires, new plugs...
01 F150 (my project truck) - got the fenders off around the engine bay, cab's lifted 8 inches, about to start disconnecting hoses/wires from the engine. Dropped the driveshafts. Getting ready to pull the engine/tranny for a deep rebuild.
04 avalanche - brake lines and front light housings, oil change and other light maintenance.
07 taurus - maintenance
jaybird
Post by jaybird on Jan 28, 2019 15:33:32 GMT -5
Added some Honda red grips to my '80 XL185S. I low sided her last summer and never got around to replacing them. Got bored and untarped my GSXR 600 powered T bucket. Took some measurements for the frame, I'm going to go with 1"X3" box beam. Hope to get the frame mocked up soon.
Post by milly on Jan 29, 2019 18:16:11 GMT -5
Cant remember where i left off, but its apparent i need to open a service shop. 03 forester - valve cover gaskets, radiator flush, waterpump, and rotors/pads/calipers all around. 01 grand am - ignition switch (and tumbler + reprogram keys), starter, battery, ground strap to the engine, exhaust splice ahead of the o2 sensor. 06 trailblazer - front wheel bearings, cv axlesn front brakes, 4 new rubbers, gritblasted and painted the spare rim, new rubber and balanced, vct solenoid, plugs, and map sensor - ordered a set of front coil springs, will be fitting them feb 2nd. 03 trailblazer - brakes, plugs, coilovers, vct solenoid cleaned, map sensor, and blower fan 97 grand cherokee - in the works - alternator blew the RR circuit diodes, very high ac voltage everywhere. This right after it came back from a shop that "fixed" something electrical. (I reeeeeally hate electrical work) 16 cruze - maintenance stuff, oil change, coolant flush, rotate tires, new plugs... 01 F150 (my project truck) - got the fenders off around the engine bay, cab's lifted 8 inches, about to start disconnecting hoses/wires from the engine. Dropped the driveshafts. Getting ready to pull the engine/tranny for a deep rebuild. 04 avalanche - brake lines and front light housings, oil change and other light maintenance. 07 taurus - maintenance Busy man, makes me dizzy thinking about doing all that 😵
Post by scooterpimp on Feb 2, 2019 18:20:07 GMT -5
Put some washer fluid in my truck.
Post by sToRm on Feb 6, 2019 19:25:42 GMT -5
Finally got around to installing some new wheels, lights and decals to my Drift cars. Skyline R34 GTR Toyota Supra Subaru STi
Mitsubishi Evolution X
Post by Happypancake! on Feb 6, 2019 22:46:36 GMT -5
Nice work
Post by aeroxbud on Feb 7, 2019 3:14:09 GMT -5
Someone's dream garage right there. 😁
Post by FrankenMech on Feb 7, 2019 9:24:53 GMT -5
Nice work! What scale are those cars?
Post by sToRm on Feb 7, 2019 11:02:56 GMT -5
Nice work! What scale are those cars? Thanks. They are all 1/10 scale with electric motors.
Post by milly on Feb 10, 2019 7:06:56 GMT -5
Wrenched on the Yamaha xt today put on new throttle cable , battery on charge then stripped carb which was full of gloop. Time to drain tank next. Son in law called by so work stopped and now throwing balloons and dancing with two and half year old grand daughter. Much better than dirty old motorcycle 😊
Post by oldgeek on Feb 10, 2019 10:40:06 GMT -5
Yesterday, I cleaned and oiled up a couple handguns and took my daughters to the indoor range. They went through just over 300 rounds. Today my fingers hurt from loading mags. youtu.be/jaE-tOC7LUgyoutu.be/f-5uGotLmfo
Post by 190mech on Feb 10, 2019 18:22:18 GMT -5
Yesterday, I cleaned and oiled up a couple handguns and took my daughters to the indoor range. They went through just over 300 rounds. Today my fingers hurt from loading mags. youtu.be/jaE-tOC7LUgyoutu.be/f-5uGotLmfoI was an autoloader guy for 10's of thousands of rounds(45ACP),then read an old book by Ed McGyern called 'Fasy and Fancy Revolver Shooting',bought some double action revolvers and hav'nt looked back since!Super easy to reload(yeah,only 6 shots,2 is all I need..),,Takes some practice shooting DA only,but we were ringing old 25lb freon jugs at 100 yds easily(redneck rules were 4" barrel max)..
Post by oldgeek on Feb 10, 2019 18:37:47 GMT -5
Yesterday, I cleaned and oiled up a couple handguns and took my daughters to the indoor range. They went through just over 300 rounds. Today my fingers hurt from loading mags. youtu.be/jaE-tOC7LUgyoutu.be/f-5uGotLmfoI was an autoloader guy for 10's of thousands of rounds(45ACP),then read an old book by Ed McGyern called 'Fasy and Fancy Revolver Shooting',bought some double action revolvers and hav'nt looked back since!Super easy to reload(yeah,only 6 shots,2 is all I need..),,Takes some practice shooting DA only,but we were ringing old 25lb freon jugs at 100 yds easily(redneck rules were 4" barrel max).. The 1911 style is a fine shooting gun, kicking myself for selling mine a few years back. I like the glocks for capacity and because they will most likely fire at least once when you need it, no matter what it has been through. I picked up a Ruger LCP, it is now my concealed carry. Combined with a holster that "prints" like a wallet in my back pocket. I know the revolvers are very, very reliable, been thinking about one for the nightstand. What's your pick?
Post by 190mech on Feb 10, 2019 19:29:40 GMT -5
After being a 'wheel gunner' for a few years,a backwoods hunter brought his Glock by after finding it in the swamp where he lost it a few months before(underwater)..It looked rough,but we had a 100 box of 9mm's on the bench,that thing would ring the drum at 100 yards!Darn plastic pistol amazed me!! Lots of good 'bedside' wheel guns,S&W,Dan Wesson,Ruger(GP100),Colt,Tarus,,357 is my fav as it can be used with .38 or 357,even shot shells..
Post by ThaiGyro on Feb 11, 2019 2:23:52 GMT -5
I may have mentioned that I have a recent acquisition of a Honda CRF250L, dual sport. I am now into design of some needed aftermarket stuff that actually makes sense. My love of light weight parts, carbon fiber and unobtanium will get put to good use. Friends have challenged me. The bike weighs 320 pounds. I am shooting for 275 and beyond. Fun times, except I must go work for a spell...crap thrives.
