Post by jdadesignstudio on Jul 2, 2011 17:27:14 GMT -5
Hi guys,
I just finished installing my bbk from enviromoto, Ive installed all of it except for the CVT rollers. Before I put the seat back on, I tried to start it up, but no go. I can hear the starter click, but only once. I took the spark plug out and it isnt sparking. I tried connecting the old spark plug and that doesnt spark either...
Can anybody help me out as to why it isnt working?
Thanks,
Jon
Post by 90GTVert on Jul 2, 2011 17:41:57 GMT -5
Post by jdadesignstudio on Jul 2, 2011 18:51:33 GMT -5
Ok so I feel a little stupid...one of the battery connections was a little loose...got it started and adjusted the carb-it works great now!
I had a couple of other questions though:
I installed the Uni air filter, but now I dont have any hose connected to the valve cover breather port-is that ok?
At the end of the BBK instructions here, it says to check the spark plug (for color)-if I already installed the #90 main jet supplied with the kit, should I still check the spark plug for color?
Last, I havent installed the 8g rollers yet, and I was thinking I would ride it around some before doing that. Does anyone know if the stock rollers are heavier or lighter? I was trying to determine if the 8g rollers are heavier to increase top speed, or lighter to increase acceleration (I think I have that correct...).
Thanks,
Jon
Post by stepthrutuner on Jul 2, 2011 20:20:31 GMT -5
Get a drug dealer hand held counterbalance letter scale or a digital scale. Letter scale about $4.00.
Post by 90GTVert on Jul 4, 2011 8:06:42 GMT -5
Post by Goosey on Jul 5, 2011 8:34:46 GMT -5
The heavier rollers won't really gain you any top speed as in mph. Just get you to top quicker. A lighter roller will get you quicker take off, and keep you in a lower gear to climb hills at a faster speed.
Post by lshigham on Jul 5, 2011 8:38:58 GMT -5
tango
Ad agendum semper parati
Post by tango on Jul 5, 2011 10:11:06 GMT -5
lshigham: Great find, brother. I read that with my eyes plastered to the screen! VERY good information.
Post by jdadesignstudio on Jul 5, 2011 10:14:35 GMT -5
Thanks for all the advice guys, this really helps.
Post by lshigham on Jul 5, 2011 11:17:42 GMT -5
lshigham: Great find, brother. I read that with my eyes plastered to the screen! VERY good information. Always nice to be able to read something backed up with dyno research, isn't it
Post by jdadesignstudio on Jul 6, 2011 14:12:16 GMT -5
I checked the color of the plug, its not wet and does have some color, its darker but not black-is that fine or do I need to adjust something to get a lighter color. I took a picture but it came out kinda blurry so the color looks darker than it actually is.
Post by reveeen on Jul 7, 2011 7:01:52 GMT -5
The "ideal" color for the plug is a medium tan ....... but likely you haven't traveled far enough to get a god read on it yet. These are not like 2 strokes, the plug read is not as critical, you should be fine with that #90 jet in there, and having some adjustment on the idle air screw tells you there are no major vacuum leaks. I would run it in (500 miles), change the oil, adjust the valves, and look at the plug at that time.
