Post by fender069 on Jul 5, 2011 17:50:11 GMT -5
I did the 72cc Big bore kit from Enviromoto. After the install, I can't get a spark. Touched spark plug to metal and it did nothing. I think it is the stator
Tried: - Using stock & aftermarket cdi & coil - Tested voltage regulator & ignition pickup coil with meter - Recharged battery and tried to kick start too
what could it be
Post by marshinman on Jul 5, 2011 19:02:12 GMT -5
First try the simple things that we all tend to over look. Check all your connectors and make sure that they are making connection by doing a continuity test with your meter. Use a new spark plug to check for spark If you have a alarm on the scoot, disconnect it to make sure it has not gone faulty.
Post by fender069 on Jul 5, 2011 19:36:32 GMT -5
i tested connections. all good i am using new spark plug. ngk iridium scooter has no alarm
i am going to try kill switch next * battery died. going to try again after recharging battery ** Kill switch disabled did nothing. still no spark
I looked at all wires. all look intack. The kit was done without pulling the engine.
