unclemickeyri
Live And Direct From Coventry R.I.
Post by unclemickeyri on May 2, 2018 22:22:34 GMT -5
Whats Up All I'm Mike I'm In My Early 40's And This Is The First Forum I Have Been On So I Apologize In Advance For Messing Up Or Not Knowing The Proper Etiquette...Sorry!!!
I'm Here For Information And Help On A Good Setup And Best Tune I Can Get With What I Have To Work With I Appreciate Any Help, Comments, Criticism, And Information That You Guys Are Willing To Give.....Thanks Man!!
Other Things I Have Done Are... Painted Plastics, Removed Some Plastics, Removed Factory Headlamp And Gauges, Replaced Rear Shock With A Upgraded One {Im A Bigger Guy Around 225}, Changed Throttle Control And Cable, Replaced Rear Brake Shoes, Replaced Fuel Filter And Fuel/Vacum Lines, Replaced Rectifier With Quality Replacement, Added A Fuse Panel With Kill Switch, Few Other Things So If I Can Help Any Of You With Anything That I've Done Please Feel Free To Ask
So I Would Like To Thank And Apologize To Everyone In Advance....u.m.
Post by Tanuki on May 3, 2018 1:33:59 GMT -5
Apology accepted
Post by Tanuki on May 3, 2018 1:35:21 GMT -5
Post by 90GTVert on May 3, 2018 5:51:43 GMT -5
I noticed only 1 set of sliders on the list. They may work, but you usually have to tune to get the best results. That means either having more sliders on hand or having a small scale and aluminum foil or other modification method to change how heavy they are evenly. www.youtube.com/watch?v=YkNhqEFeWVQAlso didn't notice main jets on the list. Get a kit with a selection of jets so you can dial it in.
Post by tortoise2 on May 3, 2018 9:27:55 GMT -5
TaoTao ATM 50 . . Ordered....A 50MM BBK Yet another desecrated 139QMB . . and future member of the failed bearing club!
unclemickeyri
Post by unclemickeyri on May 3, 2018 10:03:50 GMT -5
Thanks For The Welcome....I Do Have A Mostly Complete Set Of Rollers 4g- I Think 9g But At The End Of The Season Last Year I Messed Around With Those In The Stock Varaitor And Pressure Plate And Found The 7g Sliders {I Also Tried 2 Other Slider Weights 5&8 maybe } Worked Better For Me Than All The Rollers I Tried...Will This Change With The Better Quality Varaitor & Pressure Plate Etc. ?.....And Yes I Assumed The Crank Would Not Handle The Added Stress For Long And I Will Probably Order The Naraku Crank {non stroker} Is There Anything Else That Should Be Replaced While Bottom End Is Apart Besides Oil Seals/Gaskets Etc.?.....Thanks For Any Info......UM
Post by tortoise2 on May 3, 2018 11:58:34 GMT -5
Not Knowing The Proper Etiquette The Capital Letter At The Beginning Of Every Word Does Seem A Tad Weird!
unclemickeyri
Post by unclemickeyri on May 3, 2018 12:38:03 GMT -5
Just A Habbit
