The Mint Mangle - (yet another) Stella 177cc
May 7, 2018 22:28:43 GMT -5
190mech, moofus02, and 4 more like this
Post by drc174 on May 7, 2018 22:28:43 GMT -5
Hey all,
I know I know, my CA project is being pushed and pushed back. So is my wife's scooter. I just had to do this one. A friend took over a local scooter shop and to say "Good Luck" I decided to give his (broken down) Stella the "thatscooterthing"-treatment.
We are talking about a 27.000 mile old mint and rust coloured cut down Genuine Stella 150. 5 port engine with reeds.
I got the engine without cylinder, he had a seal failure before it got pushed into the back of the shop and time did not allow further work.
I gave it a good clean and ripped it apart. It already had a Mazzuchelli cut crankshaft (although, we are running reeds, the only "cut" helpful here is reduced crank case pressure for less peaky power development) and it had a lightened flywheel (the starter ring is machined off and it is balanced)
I went ahead and rebuild his clutch with 23 teeth and 65 on the primary, giving it an overall longer transmission, identical to the P/PX200 vespa models.
Around the same time I started playing with live streams.
Here is the link to said stream.
I also epoxied the cases and started cutting the ports. I have done Polinis to LML engines before and the matching process is quite... extensive.
The cylinder originally has rather low timings but a high squish, with 1.1mm. I wanted higher timings and a lower compression for less heat. So i raised the cylinder with 2 gaskests and a spacer by 1.94mm and decked the top by 1.75mm (acutally a local shop decked it for me for $45). After that I got to 121/122 degree intake. All that was left was to raise the exhaust and make it nice and wide, to 68% width and 182 exhaust duration. We are going to run a JL/Prima exhaust that was happily gifted by a mutual friend from Chicago from Moto Fabrica.
Now it was time for the intake:
Boyesen reeds, "as usual" and a PHBH 28 on a Polini intake, with uni filter. tried and tested setup, so i thought it would be the best way to go. Sounds rad too. I also mounted everything together.
It was then time to deliver the engine and mount it up at his shop, Metro Scooter in Cincinnati. First look at the bike it self and a first start video.
