xzdgx
Post by xzdgx on Jul 13, 2011 20:17:47 GMT -5
Okay im new in the moped world so sorry for my stupidness...But i have a 2008 adly thunderbike 50 cc and i want to change the clutch and torque spring but im not sure what else i need to upgrade with it ? like do i need to upgrade the belt and clutch belt also ?Ive also herd i need to get a bigger jet for he carb ?
Post by 90GTVert on Jul 14, 2011 7:48:15 GMT -5
:welcome:
Is something wrong with the clutch or is your belt slipping? The clutch and contra spring are the last places I tend to start upgrading. As long as the belt isn't slipping, it's easier to swap out roller weights instead of changing the contra spring. The clutch really isn't gonna give you any performance increase unless the current one has a problem. Even then, I'd probably try removing the clutch bell and cleaning it and the clutch shoes first.
There should only be one belt, the drive belt for the CVT. A Bando belt or a Bando kevlar belt would be good choices for an upgrade IMO. Some scoots come with a standard Bando stock, hard to know without checking.
If the spark plug is lighter than a caramel color, you may wish to try a larger main jet.
