Post by Fox on Jul 18, 2011 13:26:18 GMT -5
Yep! Get a cheap 12 volt impact from Harbor Freight. They run off the scooter's battery or a car battery. It winds up and then whack! Usually takes a few hits to loosen the nut. I hit the nut 5-7 times to tighten. You'll need it to remove the variator and clutch also. If you run it off a car battery be careful! They hit harder with more amps so you could over-tighten the nuts and strip 'em. The scooter's battery is just right. www.harborfreight.com/12-volt-1-2-half-inch-emergency-impact-wrench-92349.html
Post by 90GTVert on Jul 18, 2011 13:42:38 GMT -5
Thanks for posting the vid. I've never used an electric. Didn't know they wound up like that. I'm used to a big air gun that either removes it or breaks it quickly when you're dealing with most scooter sized fasteners.
Post by tlfreek on Jul 18, 2011 16:52:36 GMT -5
i was looking at that exact device at harbor freight - will get one today.
Post by tlfreek on Jul 18, 2011 17:38:57 GMT -5
psha - that hardly seemed worth it. Two cracks from impact driver and the bolt came out. sorta bummed I wanted to play with it more, but for right now, the impact wrench is my new favorite tool. What to go impact what to go impact? so do I really need to buy a puller or can I make one?
Post by 90GTVert on Jul 18, 2011 18:09:31 GMT -5
The pullers made just for that job work so much easier than anything else I've tried and they're pretty cheap. Just search GY6 150 flywheel puller and tons should come up under $20. Others have used steering wheel pullers before and I believe jawed pullers.
Post by tlfreek on Jul 18, 2011 19:50:06 GMT -5
yeah I just tried to be creative and fabricate a puller - it still may work, but its gonna take work to make it work.
work work work work
i love it. When i started this, i was thinking it was gonna be a 5 minute job to remove.
WRONG.
Post by Fox on Jul 18, 2011 20:33:31 GMT -5
Post by 90GTVert on Jul 19, 2011 13:19:25 GMT -5
PFS sells the same puller for a little less and shipping is cheaper.
Post by tlfreek on Jul 22, 2011 22:12:55 GMT -5
ok so this will be the post that never dies. Got the puller today, just like the nut on the flywheel it came off in less than 5 seconds.
found that I have an 8 coil stator and have now ordered it. God I hope this is the problem.
Post by 90GTVert on Jul 23, 2011 7:36:47 GMT -5
Having the right tools makes all the difference in the world. Keep us updated.
Post by Fox on Jul 23, 2011 9:45:36 GMT -5
So you were right. It is a 5 minute job if you have the right tools. Hope the new stator cures you problem.
Post by tlfreek on Jul 23, 2011 9:51:18 GMT -5
BTW - if anyone in the portland OR area needs a flywheel puller PM me. I have one. Instead of buying just the 27x1 lh I bought like 6 of all diff sizes that work on suz, kaw etc.
so if you are local PM me I will let you borrow it. same with the impact wrench and any other special tools needed that I might have
