jimfj
Scoot Junior
Post by jimfj on Jul 17, 2011 17:17:57 GMT -5
Hello,
I'm new to this forum but not new to scooters.
I currently have a Malaguti F-15 liquid cooled 50cc project that I need help with.
I want to take this up to 70cc and need the following info.
1. I can get an NCY (??) kit for very reasonable money or an Airsal which i used before on a Kymco Super 9 LC. (very good) or does someone reccomend something else.
2. Is the stock minerelli carb ok or do I need to rejet. Bigger carb?
3. is the stock expansion pipe okay or do I need to upgrade there?
I am not racing the scooter, just street riding. I have a Rocketa 250B and an 1100 Suzuki for the real go fast stuff. I just really like the quality and the looks of this scoot and want to upgrade but not have something that has to spin 10,000 rpm to make power.
any help is appreciated.
Post by jmkjr72 on Jul 17, 2011 18:06:12 GMT -5
there are tons of kits out there for lc hm engines currentyl i am running the polini corsa kit with a leo zx pipe some ones to consider are the top performance stage 6 polini malossi all have kits that will make peak power just under 10,000 rpm and will work with oem pipes and carbs just stick to the sport kits any kit for the yamaha aerox 50 cc lc will work for you i belive there are about 75 diffrent kits out there for the lc hm engine
Post by 90GTVert on Jul 17, 2011 18:23:20 GMT -5
Like jmk said, stick with sport level kits to keep the revs low. Try browsing a site (like www.sipscootershop.com for example) that lists peak power RPM for a lot of it's pipes and cylinder kit. Sites like that can be very helpful for choosing components that mesh well. SIP even gives upjetting and carb size recommendations for some items.
jimfj
Scoot Junior
Post by jimfj on Jul 17, 2011 21:29:26 GMT -5
thank you for the suggestions, do you have any favorites or any to stay away from?
Post by 90GTVert on Jul 18, 2011 5:27:55 GMT -5
I'm not that familiar with the LC stuff. It's hard to go wrong with the big names, but for sport kits I've had good luck with about anything including cheap eBay cylinders. I like cast iron kits for street scoots vs aluminum. You'll soft seize most of the time instead of burning a hole in the top of the piston if you run lean.
Post by jmkjr72 on Jul 18, 2011 13:38:00 GMT -5
i would say one of the best bangs for your buck is the top performance trophy kit top performance is the high performance division of minierlli
Post by stepthrutuner on Jul 18, 2011 14:18:18 GMT -5
i would say one of the best bangs for your buck is the top performance trophy kit top performance is the high performance division of minierlli I can certainly 2nd that. My TP Trophy Series has served me well and the power is broad and satisfactory. It comes pretty close to being the 'best bang for the buck' IMO. Motoforce makes a similar kit that is cheaper and supposed to be pretty durable but I cannot vouch for it.
jimfj
Scoot Junior
Post by jimfj on Aug 16, 2011 10:11:06 GMT -5
I ended up with an NCY 70cc Kit. It seems to work well. Now Im in the tuning phase.
Starting another thread.
