Post by spanky4x4 on Jul 18, 2011 11:43:14 GMT -5
first post. i have been reading alot on the board and all i can say is"wow". I got a vento zipr3i turbocam off craigslist a couple monthes back for free. original owner thought it needed ignition work. i did nothing to it and have been riding it eversince. almost 300 miles. it did stumble twice like it wasnt getting fuel,but nothing since.
it now has 3537 miles and i know its getting due for maintenance. tranny oil,new belt,etc.
the problem is how much i weigh. 375#. the scooter pulls me good around town,and will pull me as fast as 43mph(had my wife pace me in her car to check). it does work really hard on the hills and slows down quite abit. not at all unexpected, but after reading so much on here i know it can do better,even if it requres more maintenance. i am not looking to improve top speed, but i dont want to lose it either. nor am i looking to gain a quicker take off. it actually does pretty good. it would be nice to be able to maintain a little better speed and throttle responce on the hills.
I am thinking derestrict the variator if it has a washer, and a 1500# torque spring to start. and mabey lighter weights. am I on the right track? Thanks for any advice. :scoot2:
Post by 90GTVert on Jul 18, 2011 13:10:08 GMT -5
That's a helluva deal you got! Where are all the free scoots on my local craigslist?!? I'm not sure how to tell you to climb hills faster without gaining or losing any other performance. lol A stiffer contra spring should help, but you might be taking off faster too. It's not a bad thing, you can always use less throttle to pretend it's still as slow as stock if you'd like. Torque is what will really have you climbing hills a lot better and makes riding more enjoyable to me... but that means engine work or an engine swap, and that's a lot more money than some CVT work. I'd guess either a 1000 or 1500 contra. You can find kits from Autotech355 on eBay that include all three (1000, 1500, 2000) fairly cheap along with 3 sets of clutch springs to get you off the line faster if you so desire. Stiffer clutch springs can help sometimes with the responsiveness if you're having trouble boggging low in RPM because the clutch should slip a little and keep you from really bogging down. If the variator has a washer in it, removing it won't change hills much. If it's in place, it will actually help initial take off a little by letting the belt ride lower in the front pulley. If it's not there, it should help top speed a bit by letting the belt ride a little higher in the front pulley. The restrictor washer isn't as bad as it's made out to be, but most folks really want all the speed they can get.
Post by spanky4x4 on Jul 18, 2011 16:28:50 GMT -5
thanks. so it sound like i need to experamint a littlewith the torgue springs and clutch till i get nearer to what i like. the real problem is i am a real gearhead from way back, and would like nothing more then a stroked 90 to replace the little 50. its taking alot of self control to not just tear ito it. for now,i need to keep it reliable, and everyday,anywhere usable. Again, thanks and nice forum.
Post by 90GTVert on Jul 18, 2011 18:20:30 GMT -5
Good luck with that. I'm the same way. I said I'd leave my scoot alone when I got my first one. You can see how well that turned out. lol
mccanic
Post by mccanic on Jul 18, 2011 22:55:44 GMT -5
Post by shakerdriver on Jul 19, 2011 17:45:39 GMT -5
The down side to that set is you only get 4 different weight rollers. You'd be better to try to find a tuning set, I think autotech355 sells them. I know how you feel, I'm hitting in at 360# and I'm running a 2000k contra and 6.5g sliders. I'm not saying that setup will work for you but it works for me, good off the line response due to the 2000k contra and top end due to the 6.5g sliders.
mccanic
Post by mccanic on Jul 19, 2011 20:55:30 GMT -5
those kits are awesome for the price! and it is a tuning set
Post by MAReames on Jul 20, 2011 1:36:32 GMT -5
Last i checked AutoTech doe snot have tuning kits in that size. I did find one on ebay once with like 15 differant sizes I will see if I can find it again.
Post by 90GTVert on Jul 20, 2011 7:27:04 GMT -5
6 each 3-8g : $34.99 shipped cgi.ebay.com/ebaymotors/MULTI-PACK-ROLLERS-ZUMA-BWS-MINARELLI-VARIATOR-15X12-EZ-_W0QQcmdZViewItemQQhashZitem3f0b4e11edQQitemZ270772605421QQptZMotorcyclesQ5fPartsQ5fAccessoriesSo that would do 3, 3.5, 4, 4.5, 5, 5.5, 6, 6.5, 7, 7.5, 8g for $35. Not bad.
Post by spanky4x4 on Jul 20, 2011 12:46:55 GMT -5
The down side to that set is you only get 4 different weight rollers. You'd be better to try to find a tuning set, I think autotech355 sells them. I know how you feel, I'm hitting in at 360# and I'm running a 2000k contra and 6.5g sliders. I'm not saying that setup will work for you but it works for me, good off the line response due to the 2000k contra and top end due to the 6.5g sliders. thanks for that. i was leaning toward something similar.glad to here i was understanding all the info around here
Post by spanky4x4 on Jul 20, 2011 12:47:48 GMT -5
6 each 3-8g : $34.99 shipped cgi.ebay.com/ebaymotors/MULTI-PACK-ROLLERS-ZUMA-BWS-MINARELLI-VARIATOR-15X12-EZ-_W0QQcmdZViewItemQQhashZitem3f0b4e11edQQitemZ270772605421QQptZMotorcyclesQ5fPartsQ5fAccessoriesSo that would do 3, 3.5, 4, 4.5, 5, 5.5, 6, 6.5, 7, 7.5, 8g for $35. Not bad. thanks for that,too! this gets ordered friday.
Post by MAReames on Jul 20, 2011 16:55:30 GMT -5
6 each 3-8g : $34.99 shipped cgi.ebay.com/ebaymotors/MULTI-PACK-ROLLERS-ZUMA-BWS-MINARELLI-VARIATOR-15X12-EZ-_W0QQcmdZViewItemQQhashZitem3f0b4e11edQQitemZ270772605421QQptZMotorcyclesQ5fPartsQ5fAccessoriesSo that would do 3, 3.5, 4, 4.5, 5, 5.5, 6, 6.5, 7, 7.5, 8g for $35. Not bad. That the set I was talking about. I just couldn't remmber how many it had.
