Post by beckostyle69 on Jul 18, 2011 18:33:35 GMT -5
Hi my name is brian my friend and me bought this 2 stroke scooter for 150 bucks. It is a viaggio eurostyle 2004 and from what i gather it is exactly the same as a vento triton r4. we cleaned the carb and new gas and it ran great all the way for like 1 hour was running perfect. I turned it off and it never worked again. I wasnt getting spark so i decided to just buy a new coil pack and plug. Immediatley it got spark so i put it all back together and then nothing. Pulled it apart again and no spark. What i have done so far.
1- new coil pack and spark plug
2- new battery
3 - took apart stator and cleaned it
Now i have a igition box i traced back the wires it is under the seat. It has two black wires hanged out each end one is grounded the other is just loose i have no idea what it does. I also had something in the front in the middle that looks like a horn. its red an dblack wit ha cream plastic center. it has a red and black two plug that runs all the way under the bike and back to the igintion box. I have no idea what it is. I looked at the trouble shooting guide here and there is a part that talks about an alarm. If that is an alarm is it possible that it would stop it from getting spark and turning over. And if that is the case is there a way to by pass it? Maybe splic the red and back together and completing the circuit jumping it out completely. I am desperate for help i miss my scooter and my friends all have them. Any and all help is welcome and any questions or what i can be clearer on i will try. Right now i have everything apart and was considering re doing all the conections with shrink heat seal butt connectors.
Thank You and Hopefully I can get help!
Brian
2- new battery
Brian
