mccanic
Post by mccanic on Jul 22, 2011 16:30:07 GMT -5
i am wondering if you need to change the blinker rely to use LED lights for the blinker?
Post by 90GTVert on Jul 22, 2011 17:19:08 GMT -5
Sometimes. I did it to 2 scoots. One worked, one did not. That's if you are using all LED signals. If you only swap front or rear to LED the other bulbs should create enough load that it works OK.
You'll wanna get a flasher that uses it's own ground, a 3 prong. I tried some 2 prong that said they worked for LEDs and they did not. The three prong worked for me.
mccanic
Post by mccanic on Jul 22, 2011 17:22:33 GMT -5
im only doing the front. if my rely is already a 3 prong will i work or are you talking about a hel bolb flasher or a led flasher?
Post by 90GTVert on Jul 22, 2011 17:27:17 GMT -5
Might work if it's a 3 prong. My 2Ts all use 2 prong flashers and I had to pick up a 3 prong from an auto parts store. Well, not 3 prong I guess. 2 prong and a ground like this... www.amazon.com/Prong-LED-Flasher-Volt-Round/dp/B0051ZHPRKJust doing the front it shouldn't be an issue anyway.
mccanic
Post by mccanic on Jul 22, 2011 17:39:30 GMT -5
okay well we will see when i get to that point in my build! i got my l/c cylinder to day from partsforscooters it has a 3 port exhaust! alot of ruff casting though nothing a little work can't do. also getting better and better at walking everyday so ill be starting my build soon!
