Post by jmkjr72 on Jul 27, 2011 16:39:10 GMT -5
you have a couple diffrent types of 2 stroke oil boat 2 stroke tcw-3(you shouldnt use this in an air cooled scooter) then you have injector and pre mix oils
yes there is some snowmobile oils 2s and i would stay away from them they are a bit ligher for the extreme cold temps to flow thru the injector
the reson i say stay away from boat and snowmobile oils is your fuel oil mix doesnt just lube your engine but it cools it also
kglazer
Post by kglazer on Jul 31, 2011 13:42:25 GMT -5
What is a good brand is repsol and if i do the 70cc will my oil injector still work with it or will i need to do premix and is it that much of a pain in the ass to have to put in premix?
kglazer
Post by kglazer on Aug 1, 2011 16:25:54 GMT -5
Post by 90GTVert on Aug 1, 2011 18:47:53 GMT -5
I could have sworn I replied to this last night. :dunno:
I don't think premixing is a big deal at all. I do it with all of my 2Ts. It takes maybe 30 seconds extra each visit to the pump once you get used to it. I try to keep a few gallons at home premixed to make for fast fill ups on the way out. I always fill up the same size container with the same amount of fuel so I always use the same amount of oil and don't even have to think about it that way. You will get to remember the amount of oil you need per gallon quickly (I use 2.56oz per gallon for 50:1 with my AMSOil). As long as you can do math in your head, it's quick. Just make sure you carry your oil in a container that has ounces clearly marked on it to make things easy on you.
Repsol is a good brand, but I believe they make more than one 2T oil and I'm not up on them.
Post by Thebatman on Aug 2, 2011 6:53:50 GMT -5
i like motul 800 2t oil......lol
