Post by kymcotallinn on Jul 25, 2011 8:34:30 GMT -5
Hi to All,
if anyone knows, stock/original settings of any 4 stroke chinese scooter. And what I am looking for, vario settings: rolls, cluts springs, torgue spings, etc. If all is stock, then what weight are rolls...etc.
Thank you to all!
Post by 90GTVert on Jul 25, 2011 9:37:50 GMT -5
Roller weights for the GY6 50 are commonly 6.5g or 8g IIRC, and the 6.5g equipped scoots perform better. Contra and clutch springs are just stock. I dunno what strength they are or anything. It's easy enough to find stock replacement clutch and contra springs. Stock clutch springs would be part # 151-142 and stock contra is part # 151-144 at PFS.
Post by kymcotallinn on Jul 26, 2011 10:05:58 GMT -5
Roller weights for the GY6 50 are commonly 6.5g or 8g IIRC, and the 6.5g equipped scoots perform better. Contra and clutch springs are just stock. I dunno what strength they are or anything. It's easy enough to find stock replacement clutch and contra springs. Stock clutch springs would be part # 151-142 and stock contra is part # 151-144 at Parts For Scooters. Thank you! I will definetly order from them.
Post by ososlow on Jul 26, 2011 16:29:55 GMT -5
my rollers were 5g
Post by Goosey on Jul 28, 2011 19:34:59 GMT -5
Usualy rollers are changed/lowered to 4.5-5g to improve take off and hill climbing.
Post by kymcotallinn on Jul 29, 2011 8:05:53 GMT -5
at the moment there is 5g slider rolls, but I already ordered 6gramm sliders, just to test.
Thank you for the answers.
Post by kymcotallinn on Aug 29, 2011 2:31:50 GMT -5
Ok, after long search I got the answer from one of the retailers, Stock torgue spring is about 860rpm So if you even put into CVT malossi white, it will be already bigger torgue, as this is 1000rpm. This post is just for info
Post by kymcotallinn on Sept 9, 2011 7:19:34 GMT -5
got finally Polini Variator with 6,9gramm rolls, what I can say...very very good perfomance.
