Post by toquima99 on Jul 26, 2011 19:48:21 GMT -5
Japanese carb for 49cc with a 85 main jet, 35 idle jet, 72cc big bore kit from Las Vegas "Scrappy Dog Scooters" Iridium spark plug, straight through perfomance muffler with matching header. Koso performance variator with Koso 7g rollers, Gates belt.
How does my setup rate? The 35 idle jet improved off throttle response at 49cc, should I increase to 40 now that it's 72cc? Still taking it easy to set the rings and break in. How long does it take for break in? I will do a WFO GPS run to check top speed when the break in is done.
