Post by jerroldp89 on Jun 20, 2018 13:47:30 GMT -5
I am having issues with my 49cc tao tao scooter. I just replaced the battery and fuse but now my electric start isnt working at all but the kick start does. As well when I put on the low beams I loose all lights. When on high the lights work but are weak unless I'm on the throttle. I'm not very mechanically incline and need help figuring out the issue.
Post by pinkscoot on Jun 20, 2018 15:05:51 GMT -5
It sounds like a short or crossed wire. My advice is to go through your wiring and see if you find a bare wire or bad connection. Then check that all of the switches are working correctly, it could be a bad starter switch or starting relay. Follow through Brents No Start thread here. I used the thread just this morning and found a bad starter. Let us know if you find anything.
Post by geoffh on Jun 20, 2018 15:48:47 GMT -5
Just have a quick check to make sure you hooked up all the wires to the battery when you changed it,there might be a loose one you missed,I would also clean the connections with sandpaper just to be sure.
geoff
