Post by snakeplissken on Jun 21, 2018 9:21:36 GMT -5
I just installed this kit on my scooter after blowing up the piston on the Naraku 70cc i had in it. I'm using Delloro 22mm carb 105 mail jet needle on last groove also using uni air filter. Weights are 5 .3 grams and using red contra with red spring in a Naraku clutch. My question is their a way to get rid of the slight delay when you first hit the gas before it takes off like a bat out of hell. I tried 4.5 slider weights but the rpms were just way too much when the power band hit. Any suggestions?
Post by ThomasTPFL on Jun 21, 2018 12:06:27 GMT -5
Metering needle. Last groove. Do you mean it's in it's richest or leanest position?
If it's in the richest position I'd try dropping it a notch or two and seeing if that helps any.
Post by snakeplissken on Jun 21, 2018 12:19:28 GMT -5
Needle clip is at top so its at leanest position
Post by ThomasTPFL on Jun 21, 2018 23:14:23 GMT -5
Did you change anything other than the cylinder kit?
Post by snakeplissken on Jun 22, 2018 14:03:39 GMT -5
It has a Stage 6 Replica pipe on it. could the lag be because i am using the red contra and red clutch springs. they are rated at 2000 rpm. I also heard the lag could be caused by using a uni filter. Once it goes i bet its going 70mph plus. Its just the lag that sucks when taking off
Post by repherence2 on Jun 22, 2018 20:57:24 GMT -5
Do you think the clutch needs to be stalled to a higher rpm? But your clutch is probably maxed out with the red +2000 springs.
Post by snakeplissken on Jun 23, 2018 13:29:00 GMT -5
I tried yellow contra and yellow springs(1500rpm) and it falls out of the power band where the red springs and red contra keep it in the power band much longer
