mccanic
Post by mccanic on Aug 4, 2011 15:04:31 GMT -5
haha soon, after i get the rad mounted then im taring into the engine!
Post by 2strokd on Aug 4, 2011 15:06:13 GMT -5
Sweet, sounds good man :popcorn:
Post by stepthrutuner on Aug 4, 2011 15:14:42 GMT -5
mccanic
Post by mccanic on Aug 4, 2011 15:43:59 GMT -5
ill be working on it this weekend most likly wait for pictures and lots of them!
bigjeff
just scootin
Post by bigjeff on Aug 4, 2011 17:21:08 GMT -5
:thumb:
mccanic
Post by mccanic on Aug 4, 2011 22:13:19 GMT -5
im getting mad! i ordered a pump then blinkers and then those jdm lesses and the lesses came first all coming from over seas! its been close to a mounth now!
mccanic
Post by mccanic on Aug 5, 2011 20:15:06 GMT -5
Did some work tonight on the rad mounting :thumb: top left bottom right Can anyone guess where the rad came from? :drool: only two more mounts :rockon:
Post by 90GTVert on Aug 5, 2011 20:31:54 GMT -5
That's a nice looking job and good work.... and I hate to be the bearer of bad news... but I think you'll have to redo it. You won't have the fan shroud there anymore with the liquid cooled setup. The water pump has a different housing that will be there. Check out some of the pics in jmk's LC conversion... 49ccscoot.proboards.com/index.cgi?board=builds&action=display&thread=1628&page=1I like the idea of keeping the rad right with the engine, but I'm not sure about the ability to pass fresh air through the it properly.
mccanic
Post by mccanic on Aug 5, 2011 20:41:20 GMT -5
remember im doing a electric pump!
Post by 90GTVert on Aug 5, 2011 21:06:42 GMT -5
Ah. ;D Well then, now you need to figure out a different fan for the flywheel that moves air through the radiator.
mccanic
Post by mccanic on Aug 5, 2011 21:58:03 GMT -5
on the ruckus's the fan pulls the air throw it too so im going to leave it.
Post by 190mech on Aug 6, 2011 6:59:29 GMT -5
The fan pulls a bunch of power from the engine!Dont use it!!
mccanic
Post by mccanic on Aug 6, 2011 7:15:18 GMT -5
I don't think that it pulls that much, ill do a test when its running, to see if the little fan spins up faster then the big one thats on it. witch i know the little one will but if it becomes a problem i can change the set up.
Post by 2strokd on Aug 6, 2011 7:17:01 GMT -5
Ohh, it does! I was using a fan smaller than that on my 103. Took the 49cc fan off and dropped a half second off my ET at the track.
Post by lshigham on Aug 6, 2011 8:05:04 GMT -5
It's around 1hp the fan takes, significant losses.
