mccanic
Post by mccanic on Jul 29, 2011 19:59:53 GMT -5
I am starting my build now as im getting better at walking!! :rockon: my goal with this build is to hit 80mph I think i can do it. plans are hoca 54mm l/c cylinder, 45mm stroker, and all the goodys to match! Day after i got it. The kid i bought it from really beat the hell out of it!:// poor thing lol, well now its in the right hands! The gooodys! :itshere: Cylinder sweet quick throttle!
mccanic
Post by mccanic on Jul 29, 2011 20:03:26 GMT -5
Worked on a few things today, cut the rack for a cleaner look! little more grinding... also make a custom jdm tail light lol just waiting on the leases. just used some jb weld. but first you drill a 7/8 hole. Much much more to come! ;D
Post by jmkjr72 on Jul 29, 2011 20:03:31 GMT -5
good luck with 80 you got gears and an over range planed in this build to get there right
mccanic
Post by mccanic on Jul 29, 2011 20:06:03 GMT -5
oh yah! haha i only weigh 130
Post by 90GTVert on Jul 29, 2011 20:22:04 GMT -5
Glad to hear you are walking better. I think it can be done as long as you're willing to stick with it and spend time tweaking. I think I was still 275lbs when I did 72MPH GPS on flat ground. Stock gears, no overrange. I think my setup even has more potential. LC should let you push more compression than my AC setup, so there's another advantage. I will tell you now that revving 12,000RPM with a 103cc is not gonna happen out of the box with that cylinder kit. If you get the cylinder to do it, you need a pipe that is meant to do that. 190mech's custom Peace Pipes are the only pipes I know of meant to bolt on to 103ccs that can support that kind of RPM. The other option would be to see just how far you can get with different gears and/or an overrange CVT. I know I couldn't do it that way, but you are also 145lbs lighter than I was last time I tried to get a good speed so you won't need as much power. Cool project. I like the ambitious goal. Please keep us and ask if you need help!
mccanic
Post by mccanic on Jul 29, 2011 20:35:14 GMT -5
i am getting a peace pipe 190mech is building it, probably as we speak. im going to go major porting to the cylinder and case, i think i can do it!!
Post by 2strokd on Jul 29, 2011 21:13:33 GMT -5
This is cool :rockon: . Best of luck with it.
:popcorn:
mccanic
Post by mccanic on Jul 29, 2011 21:21:11 GMT -5
thanks man!
Post by jmkjr72 on Jul 29, 2011 21:44:00 GMT -5
wahiduddin.net/calc/calc_speed_rpm.htmHere's the math problem, if you just want to do it that way: (0.00595) * (RPM * r) / (R1 * R2) = vehicle speed in miles/hour where: RPM = engine speed, in revolutions/minute r = loaded tire radius (wheel center to pavement), in inches = 9.8 with stock tires R1 = transmission gear ratio = total final drive, so for 08+, 13.228, and 05-, 14.664, or the ratio you want. R2 = rear axle ratio = 0.889 at highest pulley 'gear' ratio with stock 05 gearing it takes 12000 rpm to hit 54 you will need 42/14 to even be able to get to 80 mph so you will need a ton of power to pull those gears and be able to rev to 12000 rpm to get there without an over range Attachments:
mccanic
Post by mccanic on Jul 29, 2011 22:03:43 GMT -5
i don't need your math problem, ive over come all the problems in planing, this is why im doing it the way im doing it. you just sit back, eat some pop corn and watch!
mccanic
Post by mccanic on Aug 2, 2011 13:39:19 GMT -5
update: i was bring my shaddydog engine into the garage to mount the rad and hurt my leg! :/ so there mint be a little bit of an update coming soon, of the rad being mounted.
mccanic
Post by mccanic on Aug 4, 2011 13:13:15 GMT -5
got my JDM leases in this morning! here it is all done :rockon:
Post by 90GTVert on Aug 4, 2011 13:22:20 GMT -5
Nice improvement. :thumb:
mccanic
Post by mccanic on Aug 4, 2011 14:50:36 GMT -5
oh yah now im getting rid of them stupid blinkers. well i did to make this tail light lol thanks man
Post by 2strokd on Aug 4, 2011 15:03:06 GMT -5
Cool! Looks good! Is it getting "killer fast" yet?
