xzdgx
Bogging
Aug 1, 2011 23:04:50 GMT -5
Post by xzdgx on Aug 1, 2011 23:04:50 GMT -5
My scooter bogs really bad when i take off,and also when the powerband hits its very week and not very powerful when it hits it.I looked at my air box to make sure it was all sealed up and stuff so its not getting too much air,im just not sure what else it could be i need help please.
Post by 2strokd on Aug 2, 2011 7:50:32 GMT -5
What kind of scoot? Did you try to richen the idle/air mix a tad?
Bogging
Aug 2, 2011 12:15:22 GMT -5
Post by 1quikvento on Aug 2, 2011 12:15:22 GMT -5
I had very good results with adjusting both my idle screw and my idle mixture screw. Make sure your throttle cable is in good shape.
xzdgx
Bogging
Aug 2, 2011 13:39:28 GMT -5
Post by xzdgx on Aug 2, 2011 13:39:28 GMT -5
Ive got an adly thunderbike 50cc and i havn't tried that eather
Bogging
Aug 2, 2011 15:32:48 GMT -5
Post by 2strokd on Aug 2, 2011 15:32:48 GMT -5
I would try turning the idle/air screw in a tad. The one that is recessed in the carb, closest to the airbox
xzdgx
Bogging
Aug 2, 2011 19:05:41 GMT -5
Post by xzdgx on Aug 2, 2011 19:05:41 GMT -5
okay thanks !also i have stck roller weights and mmy scooter is stock aside from a peformance cdi,what weight roller weights should i put in it.Or should i mix them with 5 and 6 ?
Bogging
Aug 2, 2011 19:40:00 GMT -5
Post by 90GTVert on Aug 2, 2011 19:40:00 GMT -5
I'd guess 4-5g. If you already have 5 and 6g try the 5s and see if you think they should be lighter or heavier after riding. Revving too high, go heavier. Not enough revs, go lighter.
xzdgx
Bogging
Aug 3, 2011 11:04:54 GMT -5
Post by xzdgx on Aug 3, 2011 11:04:54 GMT -5
Cool man,thanks.Also what size will i need some say like 15x12 and like 16x13 and so on.But im not sure what size i would need?
Bogging
Aug 3, 2011 11:12:42 GMT -5
Post by 90GTVert on Aug 3, 2011 11:12:42 GMT -5
15x12
