smoking
Aug 3, 2011 14:09:13 GMT -5
Post by vegasman42 on Aug 3, 2011 14:09:13 GMT -5
i have a tao tao. i installed the BBK. been running fine for about 5 months. i was riding one day and it lost power gradually now it smokes badly. on of the rings gets stuck on the piston. i freed it up and it ran without smoke for about 10 mins then started again. is there something i can do short of a new piston?
Bong
smoking
Aug 3, 2011 15:41:05 GMT -5
Post by Bong on Aug 3, 2011 15:41:05 GMT -5
Wow, I told you guys Vegas was a scoot town!!!! Anyways, How many miles and what size bbk 72/83?? At the very least new rings but, possibly a rebuild if other damage is done. Go to Scrappys and get new rings and a piston. Cheapest prices in town and Rick is on Tropicana since your local.
smoking
Aug 3, 2011 19:02:14 GMT -5
Post by jmkjr72 on Aug 3, 2011 19:02:14 GMT -5
see your little 4 stroke is just wishing it was a big mean 2 stroke :scoot: :scoot: :scoot: :scoot: :scoot:
Post by vegasman42 on Aug 4, 2011 0:54:23 GMT -5
mine is a BBK 83. is it possible to widen the ring groove or would that be dangerous. i have no idea.
Post by 90GTVert on Aug 4, 2011 7:14:57 GMT -5
As long as nothing is damaged, I'd get a new set of rings, gap them, and install them. It should be fine after that. Just make sure the ring lands (grooves) are clean before installing the new rings. If you can't get it clean for any reason, get a new piston too. There should be no need to make the ring land larger.
theo547
smoking
Aug 4, 2011 15:42:19 GMT -5
Post by theo547 on Aug 4, 2011 15:42:19 GMT -5
could gas from a rusty gas can cause smoke?! i just installed a 83cc kit also and mine is smoking terribly.
smoking
Aug 4, 2011 18:35:39 GMT -5
Post by jmkjr72 on Aug 4, 2011 18:35:39 GMT -5
yes gas that has water in it can cause a white smoke
blue is rings
