Post by embligen1150 on Aug 1, 2018 12:18:37 GMT -5
Gator 50cc 4stroke 2016. Has no power. Only runs 20 mph. No washer in variator. No needle adjust. 82 to 85 jet made it worse. Can I get a derestricted cdi that will help this unit?
Post by embligen1150 on Aug 1, 2018 12:22:26 GMT -5
And will a aftermarket variator fix the problem.
Post by 90GTVert on Aug 1, 2018 13:36:13 GMT -5
What's the story? Has it ever ran well for you or did you just get it and this is how it is? You should not need performance parts to top 20MPH. Most stock 4T scooters will go 30-35MPH in stock form if they're running right.
Post by embligen1150 on Aug 1, 2018 16:38:49 GMT -5
Post by embligen1150 on Aug 1, 2018 16:39:57 GMT -5
Freind just bought it. Trying to help out.
Post by embligen1150 on Aug 1, 2018 17:19:08 GMT -5
Is this a qmb139 motor?
Post by embligen1150 on Aug 1, 2018 17:20:53 GMT -5
What should compression be. Can valve adj help. 5700 miles.
Post by 90GTVert on Aug 1, 2018 18:31:37 GMT -5
Healthy should run something like 150psi.
Has it sat around with old gas? If so, drain it, clean the carb, and go over the fuel system.
Post by humanshield on Aug 4, 2018 10:22:23 GMT -5
What should compression be. Can valve adj help. 5700 miles. I've got em to run with only 80psi (very weak)
To ride it you probably need at least 120psi
I like mine around 150- 170psi or so.
Too high and it'll run hot, be hard to start and pound the bearings.
ymmv
Post by GrumpyUnk on Aug 6, 2018 10:31:46 GMT -5
To answer the question, yes, a valve adjustment might help, especially if the valves need adjustment. If mis-adjusted, the valves may not seat well causing compression to be lower than normal. That definitely could affect starting and power developed, moreso when hot. tom
