Post by jwinn on Aug 4, 2018 7:23:52 GMT -5
Gonna try and change the oil today. After looking over posts and the user manual, 15w-40 is suggested. I can't seem to find any 4T 15w-40 oil. Only 4T 10w-40 or heavy diesel 15w-40. Unless i want to spend $30 on a 4-5 qt bottle. Which i really don't have the money for.
Will it be okay to use the 15w-40 diesel? Or does it need to say 4T?
Post by 90GTVert on Aug 4, 2018 7:33:04 GMT -5
It doesn't have to say 4T. Just don't buy any oil that says 2T. You don't need a motorcycle oil for these, because they don't have a wet clutch. Automotive oils work. I use Shell Rotella T 15W40 diesel oil. 10W40 is OK too if you wanna use that. Quite a few 139QMB riders use it.
Post by jwinn on Aug 4, 2018 7:37:19 GMT -5
Thanks for the quick reply 90GTVertIs this the one
Post by 90GTVert on Aug 4, 2018 9:18:59 GMT -5
Yup.
Post by jwinn on Aug 4, 2018 9:22:56 GMT -5
Cool. Thanks brother.
Post by humanshield on Aug 4, 2018 10:09:30 GMT -5
I use Shell Rotella T 15W40 diesel oil too. Good stuff.
tas50
Post by tas50 on Aug 4, 2018 10:15:28 GMT -5
I also use Rotella in my ‘79 Suzuki GS850, ‘04 ttr125, and ‘04 SV650 race bike. they all love it.
Post by scooterpimp on Aug 4, 2018 20:13:04 GMT -5
I use whatever is on sale that day.... (15w40)
Post by jwinn on Aug 4, 2018 20:16:53 GMT -5
Not sure what the scoot shop used previous. I was probably a couple hundred over on the oil change. Engine would give a umm...hiccup(?) during idle.
After 15w-40, hiccup seems gone and sounds better.
Post by gsx600racer on Aug 4, 2018 20:46:04 GMT -5
Iv used Rotella T 15W40 in my older lawn equipment without issues. Never ran it in a scooter tho.
Post by jwinn on Aug 4, 2018 21:11:07 GMT -5
gsx600racer where'd you get your avatar? Dying to watch the full clip in fullscreen.
Post by gsx600racer on Aug 4, 2018 22:51:56 GMT -5
gsx600racer where'd you get your avatar? Dying to watch the full clip in fullscreen. The full video is gone. This is all i could find.
Post by jwinn on Aug 4, 2018 23:07:57 GMT -5
Post by greginisn on Aug 5, 2018 2:06:54 GMT -5
If you were to ride in sub freezing weather that might be a good question but with 2 wheeled machines the lower number is relatively meaningless just buy your favorite oil in what ever weight span is available. I don't think you should even consider using a diesel rated oil in a gas engine. Different additives, different SAE ratings on the oil.
Greg
Post by GrumpyUnk on Aug 6, 2018 10:44:44 GMT -5
I'd recommend Shell Rotella, Mobile Delvac, and Chevron Delo. Walmart SuperTech is also on my list as it is made by a national petroleum company(Marathon?). The 15W part is quite good for cold viscosity and the -40 part should provide good hot protection.
The added factor biasing me in choosing compression ignition rated(diesel) is that they still have some ZDDP added. These engines have sliding friction on the cam followers/rocker arms. ZDDP helps protect the sliding surfaces, and is not necessary in 'roller' lifters/cam followers. tom
