Post by stancejontland on Aug 6, 2018 21:52:44 GMT -5
hey guy, i have a hyper tough h2500 series weed eater and all of the sudden the primer bulb stopped working. it wont suck and fuel in at all and when i press it it stays sucked in. only goes back only when i pull the gas line off of it. i will get some pictures of it because its not like other bulbs. my other 2 weed eaters have the same but not as the hyper tough one. the one im having issues with the bulb is like a plate that has a "cardboard" gasket and a thin plasticy secondary gasket. cant find them anywhere!!!
Post by gsx600racer on Aug 6, 2018 21:57:32 GMT -5
Tear the carb apart. There is a small screen inside that might be cleaned. Wouldn't hurt to replace all fuel lines with Tygon ones
Post by stancejontland on Aug 6, 2018 23:21:22 GMT -5
Its barley the summer old. I think the lines should be good?
Post by gsx600racer on Aug 6, 2018 23:58:10 GMT -5
If they are black rubber fuel line then chances are they have broken down over time from the ethanol in the gasoline. This is usually after the filter in the tank and the particles of fuel line will muck up the carb. If you using true fuel or any other ethanol free gasoline you might be fine. Ethanol and rubber do not play well together.
Post by stancejontland on Aug 7, 2018 1:21:19 GMT -5
yeah its a black line and a bluish line.
Post by stancejontland on Aug 7, 2018 14:33:13 GMT -5
ok so i cleaned the carb and still no priming or starting. blew it out with the air compressor.
Post by stancejontland on Aug 8, 2018 3:08:46 GMT -5
Messed with it all day and still no fuel to primer bulb. Blew out the lines. Sprayed carb with ether. No go. Need some other ideas. Maybe ill go get some new line and a bulb just to try.
Post by gsx600racer on Aug 12, 2018 0:47:55 GMT -5
Not sure how much more help I can offer ya. Iv worked on more of those carbs than I can count. Just worked on another one for a customer today. Here are some pics of the mess that fuel lines make when they break down. Carb screen removed Rolling while pinching fuel line. If you look close at the old fuel line you can see the deterioration inside the line. These vids might help some. Just keep in mind that the primer system "pulls/sucks" the fuel thru the carb. Mixing the fuel/return lines with make the primer system not work.
Post by stancejontland on Aug 13, 2018 0:48:15 GMT -5
i cleaned everthing out as good as i could without tearing it all apart. still wouldnt prime but i got new fuel lines and for some reason it starts now and runs but wont prime so i gotta pull it a good few times
