kglazer
Post by kglazer on Aug 18, 2011 13:21:44 GMT -5
i went and looked and all i could see was the line that runs from the oil tank to the engine was conected to a flange with a screw on each side, is that where the pump is located?
Post by 2strokd on Aug 18, 2011 23:37:47 GMT -5
Not sure were you are speaking of exactly??? Tell ya what. I will take some more pics of my oil pump on my Kymco Cobra tomm. Maybe they will help more.? And i can show people what a pump with a leaking seal looks like .
kglazer
Post by kglazer on Aug 18, 2011 23:44:35 GMT -5
That sounds awsome. I would rlly apreciate it.
kglazer
Post by kglazer on Aug 18, 2011 23:48:10 GMT -5
Please take close up pics too lol
Post by 2strokd on Aug 19, 2011 8:58:03 GMT -5
The oil pump from the right side of the scoot. As you can see, mine has been leaking The pump bolt. All you need to do to remove it is unhook the cable and lines, then take the bolt out and the pump will come out Hope this helps more.?
kglazer
Post by kglazer on Aug 19, 2011 16:29:59 GMT -5
the bolt that is covered in oil? or the one to the upper left of it with the hose attached to it? also will there be a bunch of oil coming out when i take off the bolt and pull it out?
Post by 2strokd on Aug 19, 2011 22:00:05 GMT -5
The one covered in oil. The other is a oil-line adapter. You can expect a mess if you dont plug the oil line coming from the oil tank. Unless it is empty that is? You can fallow the lines to see what one is going to the tank.
kglazer
Post by kglazer on Aug 19, 2011 22:05:24 GMT -5
There are no lines on the bolt covered in oil and theres a line from the oil adapter but that runs not to the tank. I think for some reason our engines are set up diffrently even though there the same kind.
lbo
Post by lbo on Aug 20, 2011 6:36:46 GMT -5
Post by Thebatman on Aug 20, 2011 10:11:08 GMT -5
There are no lines on the bolt covered in oil and theres a line from the oil adapter but that runs not to the tank. I think for some reason our engines are set up diffrently even though there the same kind. Its the EXACT same engine in the cobra of robs as on your a.c S9 Also the ppl has the EXACT same enine...
kglazer
Post by kglazer on Aug 20, 2011 10:24:59 GMT -5
Thats what i thought but for some reason there are no lines running from that bolt or any area around that bolt to my oil tank. So idk
