Post by pitobread on Jan 1, 2019 19:29:10 GMT -5
Cover is off
Gave it a light re press but the pulley still drags. It was tight before but now with the bits of aluminum smeared on there it drags.
Shaft is installed to full depth. Short of making a small shim to space it out something is mis machined. The bearing has a circlip so it cannot fall out the back either...
May just machine the rear of the pulley half a mm or so back, but honestly you shouldn't have to do that.
Post by 'O'Verse on Jan 1, 2019 20:27:17 GMT -5
Post by pitobread on Jan 1, 2019 20:37:56 GMT -5
Thanks man, saved me some headaches.
This complete engine sure is lacking in some pieces! I have the white spacers but the kit didnt have the black spacer. I will make one tomorrow at work
Post by ryan_ott on Jan 1, 2019 20:38:29 GMT -5
I had measured that for someone... checked my posts and the black one is 3mm the silver is .5mm.
Post by 190mech on Jan 1, 2019 20:41:54 GMT -5
Guess with heat the aluminum pulley expands making matters worse,adding some thin shims and cutting .5mm off the aft side of the pulley should polish that turd to a bright sheen...
Post by pitobread on Jan 1, 2019 20:53:01 GMT -5
Yeah it happened as I was pulling into my driveway, engine just hard stopped as I let off the gas. I had started up a hill and been into it for a second then let off and it dies.
Again no mention in any of the literature that these spacers are needed. Just leaves you guessing.
Post by pitobread on Jan 1, 2019 22:51:11 GMT -5
Post by pitobread on Jan 18, 2019 1:36:07 GMT -5
Post by SandStorm on Jan 18, 2019 1:43:24 GMT -5
She looks so sexy Damn I really want one of these typhoons
Post by drc174 on Jan 18, 2019 12:56:47 GMT -5
Fork i think you can make a lot yourself. Piaggio Fly uses 32mm fork, like the Malossi. Then you can put a compressor in the top and in the bottom. Save yourself a lot of $$. You're a smart guy, you can figure it out
Post by pitobread on Jan 19, 2019 2:13:53 GMT -5
Post by drc174 on Jan 19, 2019 21:54:24 GMT -5
Seen race track 4T’s, full Malossi, and those things flyyyyy. Little less exciting sound however
Post by Lucass2T on Jan 20, 2019 6:40:55 GMT -5
Holy cow what a waste of money that is... You buy/build so much more exciting stuff with €5k.
Post by drc174 on Jan 21, 2019 11:19:47 GMT -5
Holy cow what a waste of money that is... You buy/build so much more exciting stuff with €5k. I disagree. As someone with track/trackside experience, Malossi stuff is truly built for a purpouse. The 4T stuff is (track dependent) competitive with the 4T engines. Ofc it depends ont he base. Back in... I wanna say 2011/2013, i was in Spa (BE) and there was a guy riding the track with a Piaggio ZIP and this 4T engine in it. The less aggressive 4T made it much more malleable and controllable, especially in Spa where the turns are real tight and (used to) be bumpy. Furthermore, a 4T like this is much more manageable in terms of cost. So it gives you a really good platform to get into it with overseeable costs. And even though the engine may not push the RC-One power, as a rider you learn everything about suspension, grip, braking and acceleration. You get high end, fully adjustable suspension. If you can get that right, than you can turn up the power. Being fast starts there and ends with the engine, not the other way around. However, if you just want to ride on the road, sure.
