mccanic
Post by mccanic on Aug 6, 2011 7:24:48 GMT -5
Post by 90GTVert on Aug 6, 2011 9:37:01 GMT -5
You can definitely pick up power with the right timing curve. It would be nice if they showed you what curves you could accomplish with it. Most of the one's I've seen others post for 2Ts just retard in a linear fashion beyond a certain RPM.
mccanic
Post by mccanic on Aug 6, 2011 16:15:39 GMT -5
oh this one is probably the same then. an ajustable stator would be better!
Post by 90GTVert on Aug 6, 2011 16:51:57 GMT -5
You can get an NCY with a small and light flywheel that has grooves on the mounting plate so you can rotate it to advance or retard the base timing. 2strokd seems to be fond of his. www.partsforscooters.com/90cc_Minarelli_spark_kit_169-118You can elongate the holes in the stock pickup mount to move it roughly 3 degrees either way.
mccanic
Post by mccanic on Aug 6, 2011 17:37:01 GMT -5
yah thats the one i want!
